G400 USB Debug low, full or high speed?
Does the USB port on the G400 that is normally used for debugging operate at low (1.5 Mbits/s), full (12.0 Mbits/s) or high (480 Mbits/s) speed?
I need to operate remotely and am thinking about trying a pair of USB over Cat5 extenders like these and the cheaper ones only work at low and full speed.
http://www.tripplite.com/usb-2.0-over-cat5-cat6-extender-transmitter-receiver-high-speed-usb-330-ft-100m-1-port~B203101/
Full
Thanks, Mike.
One more question. Is it USB 1.1 or 2.0?
2.0 but that is 1.1 compatible. I am not sure if the descriptor returns 1.1 or 2.0 though.
I should have asked my question more precisely. I’d like to give these USB over Cat5/6 extenders a try. The Icron one looks like it has more engineering put into it but is USB 1.1 and the cheaper one says it is USB 2.0 but I don’t see much engineering backup to prove it. My gut says to go with the Icron but I’m not sure USB 1.1 is enough.
or
