When I deploy an application to the G400 HDR I see the following messages in the debug output window. Mike has mentioned this before, but there was no answer to that post.
Invalid address 22700510 and range 4 Ram Start 20000000, Ram end 20100000
Here is the device info, to confirm that I have the latest version of the firmware etc.
HalSystemInfo.halVersion :4.2.0.0
HalSystemInfo.halVendorInfo :Microsoft Copyright (C) Microsoft Corporation. All rig
ClrInfo.clrVersion :4.2.0.0
ClrInfo.clrVendorInfo :Microsoft Copyright (C) Microsoft Corporation. All rig
ClrInfo.targetFrameworkVersion :4.2.0.0
SolutionReleaseInfo.solutionVersion: 4.2.10.0
SolutionReleaseInfo.solutionVendorInfo: Copyright (C) GHI Electronics, LLC
SoftwareVersion.BuildDate: May 30 2013
SoftwareVersion.CompilerVersion: 410713
LCD.Width: 320
LCD.Height: 240
LCD.BitsPerPixel: 16
Here is the full output in the debug window
Loading start at 202c6aa8, end 202f5a70
Assembly: mscorlib (4.2.0.0) Assembly: Microsoft.SPOT.Native (4.2.0.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.2
.0.0) Assembly: System.Security (4.2.0.0) Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Graphics (4.2.0.0) Assembly: Microsoft.SPOT.TinyCore (4.2.0.0)
Assembly: Microsoft.SPOT.IO (4.2.0.0) Assembly: System.IO (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0) Assembly: Microsoft.SPOT.Touch (4.2.0.0)
Assembly: Microsoft.SPOT.Ink (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)
Attaching deployed file.
Assembly: Gadgeteer (2.42.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net.Security (4.2.0.0) Attaching deployed file.
Assembly: GadgeteerApp1 (1.0.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.Display_T35 (1.1.3.0) Attaching deployed file.
Assembly: System.Http (4.2.0.0) Attaching deployed file.
Assembly: System (4.2.0.0) Attaching deployed file.
Assembly: dotnetwarrior.Gadgeteer.G400HDR (1.1.1.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.Button (1.1.2.0) Attaching deployed file.
Assembly: Gadgeteer.DaisyLink (2.42.0.0) Attaching deployed file.
Assembly: System.Net.Security (4.2.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.2.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.MulticolorLed (1.1.2.0) Attaching deployed file.
Assembly: GHI.Premium.System (4.2.10.0) Attaching deployed file.
Assembly: GHI.Premium.Hardware (4.2.10.0) Resolving.
GC: 1msec 289080 bytes used, 66816684 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 66816684 bytes
Type 17 (ASSEMBLY ): 33780 bytes
Type 1E (BINARY_BLOB_HEAD ): 255204 bytes
GC: performing heap compaction...
Ready.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\mscorlib.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Native.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Security.PKCS11.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Security.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Graphics.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.TinyCore.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.IO.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.IO.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Touch.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Ink.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies\.NET Micro Framework 4.2\le\Gadgeteer.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.Security.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Button\NETMF 4.2\le\GTM.GHIElectronics.Button.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies\.NET Micro Framework 4.2\le\Gadgeteer.DaisyLink.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\MulticolorLed\NETMF 4.2\le\GTM.GHIElectronics.MulticolorLed.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Display_T35\NETMF 4.2\le\GTM.GHIElectronics.Display_T35.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\GHI Electronics\GHI Premium NETMF v4.2 SDK\Assemblies\le\GHI.Premium.System.dll'
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\GHI Electronics\GHI Premium NETMF v4.2 SDK\Assemblies\le\GHI.Premium.Hardware.dll'
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Mainboards\G400HDR\NETMF 4.2\le\dotnetwarrior.Gadgeteer.G400HDR.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'D:\Embedded\Projects\G400\GadgeteerApp1\bin\Debug\le\GadgeteerApp1.exe', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Net.Security.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Http.dll', Symbols loaded.
Invalid address 2270057c and range 4 Ram Start 20000000, Ram end 20100000
