I create a RFID reader in Application Main:
Site.RFID = new RFIDController(Settings, Logger);
RFIDThread = new Thread(Site.RFID.Start);
RFIDThread.Start();
Then RFID Start connects my serial port:
public void Start()
try
rfidSerialCommand = new RFIDSerialCommands("Com1", 19200, Logger);
rfidSerialCommand.TurnOnTransmitter();
//rfidSerialCommand.
catch (Exception exception)
Logger.LogError(Device.RFID, "Start()", exception.Message, exception.StackTrace, exception.InnerException);
Controller I call RFID method:
public bool GetRawData()
try
byte[] holder = null;
if (CheckedBlocksRead(Block00, Block15, out holder))
holder.CopyTo(CardBlocks, 0);
Debug.Print(Utilities.BytesToHexString(CardBlocks));
return true;
CheckedBlocksRead is:
ReadBlockData)
try
byte[] readBlocks = null;
int expRetLen = (4 * (endBlock - startBlock + 1));
if (rfidSerialCommand.ReadBlocks(startBlock, endBlock, out readBlocks))
Utilities.CopyPassedArrayToOutArray(readBlocks, 1, expRetLen, out ReadBlockData, 0);
return true;
Logger.LogError(Device.RFID, "CheckedBlocksRead()", exception.Message, exception.StackTrace, exception.InnerException);
ReadBlockData = new byte[1];
return false;
CALLs>>>:
public virtual bool ReadBlocks(short startBlock, short endBlock, out byte[] readBlocks)
int expectedBytes = 7 + (4 * (endBlock - startBlock));
byte lowByte;
byte highByte;
try
//byte[] readBlocks = null;
CalculateCRC16(new byte[] { 0x03, 0x23, (byte)startBlock, (byte)endBlock }, out lowByte, out highByte);
ReadBlocksCommand[4] = (byte)startBlock;
ReadBlocksCommand[5] = (byte)endBlock;
ReadBlocksCommand[6] = lowByte;
ReadBlocksCommand[7] = highByte;
if (RetrySend(ReadBlocksCommand, expectedBytes, out readBlocks)) return true;
Logger.LogError(Device.RFID, "ReadBlocks()", exception.Message, exception.StackTrace, exception.InnerException);
readBlocks = new byte[1];
return false;
private bool RetrySend(byte[] command, int expectedBytes, out byte[] bytes)
int retries = 3;
while (retries > 0)
retries--;
bytes = SerialRFIDConnection.Send(command, expectedBytes);
if (Utilities.IsEmpty(bytes, 1))
Debug.Print("Empty Bytes Returned");
continue;
return true;
bytes = new byte[1];
return false;
Serial method that finally calls SerialCode:
bytes, int expectedBytes)
BytesRead = 0;
byte[] readBuffer = new byte[expectedBytes];
try
if (!IsOpen)
Open();
// Reset Timeout
ResetTimeout();
FlushBuffers();
//serialPort.SetLength(45);
serialPort.Write(bytes, 0, bytes.Length);
Thread.Sleep(100);
//BytesRead = serialPort.Read(readBuffer, 0, readBuffer.Length);
// Loop until we get a full buffer or we timeout
while (BytesRead < expectedBytes)
BytesRead += serialPort.Read(readBuffer, BytesRead, Math.Min(serialPort.BytesToRead, expectedBytes - BytesRead));
if (TimedOut)
break;
Thread.Sleep(5);
// Read input
if (BytesRead < expectedBytes)
FlushBuffers();
Logger.LogError(Device.SerialPort, "Send(expectedBytes)", exception.Message, exception.StackTrace, exception.InnerException);
return readBuffer;
