This is probably going to be a very big ask but I was wondering if anyone has an eagle library for the G400-S and would be willing to share the library. I’m working on a prototype PCB when I have time and I was hoping to use the G400-s as the main MCP.
Thanks for info everyone, just checked with support regarding an eagle library for the G400 s but its not available. Guess i will either have to use the fez raptor or have a go at producing an eagle library for the G400 s.
@ ScubaBoy - The library file is not available from GHI, however, you can copy the schematic symbol from the Raptor schematic and a copy of the symbol w/ accompanying PCB footprint will be available for you to use without a separate library in your own design.
Learning to make libraries is a good thing anyway. Better to trust your own work than have a PCB made that’s got wrong footprints etc. Been there, done that
I use Altium Designer and creating the library part for for the G400S and G400D only took an hour or 2. Included checking and double checking etc. I am not familiar with Eagle but shouldn’t be too difficult and you’ll learn a necessary requirement at the same time anyway.
What out for the fact that the G400S has board cutout requirements.
