shm3
1
I want to read and write from serial port with G400, using RLP.
I guess I need to access to USART0 / USART1 / USART2
Where can I find the mapping between board socket and those registers?
I am working with G400 HDR board and saw that:
UART - Socket 6 - COM3
UART - Socket 7 - COM1
UART - Socket 9 - COM4
I need to know for example that COM3 is USART0 and etc.
@ shm3 - Here is the Datasheet to COM port map:
COM1: PA9, PA10 ~ DRXD, DTXD
COM2: PA0, PA1 ~ TXD0, RXD0
COM3: PA5, PA6 ~ TXD1, RXD1
COM4: PA7, PA8 ~ TXD2, RXD2
COM5: PC8, PC9 ~ UTXD0, URXD0
COM6: PC16, PC17 ~ UTXD1, URXD1
shm3
3
I am not sure I understand.
In Hydra I had this method: (serial port connected to socket #7)
void debug_print1(unsigned char *str, int numOfBytes)
unsigned char *p = str;
while (numOfBytes–)
AT91C_BASE_US0->US_THR = *p++;
while ( (AT91C_BASE_US0->US_CSR & 2) == 0) ;
now in G400 when serial port connected to socket #6 (HDR board) I thought it should be:
while (numOfBytes–)
USART0->US_THR = *p++;
while ( (USART0->US_CSR & 2) == 0) ;
am I miss something?
@ shm3 - The COM port on socket 6 is COM3 which is TXD1/RXD1 which could be the equivalent of UART/USART1.
shm3
5
Thanks!
for some reason this line is endless:
while ( (USART1->US_CSR & 2) == 0) ;
very similar code works for me in Hydra but not for G400…
shm3
6
Any idea why this code doesnt work:
while (numOfBytes–)
USART1->US_THR = *p++;
@ shm3 - I am uncertain as to why that code does not work. Your best bet would be to consult the datasheet for the G400’s processor.
