Hello,
I’m looking for some guidance on what the issue might be, I’m a first time user of GHI products and first time trying to setup a G400-D module.
Here is what I have:
- G400-D module
- G400HDR Breakout board
- USB Client DP Module
I’m on Windows 7 machine and have installed the following software in this order:
- .NET Micro Framework SDK v4.3 RTM (QFE1)
- NETMF and Gadgeteer Package 2014 R2
After installing the above, I plugged in the USB and it recognized the G400 and so far things look good.
I then used MFDeploy and did a ping and it responded with TinyCLR. Checking the device capabilities shows ClrInfo.clrVersion: 4.2.0.0.
So at this point I wanted to see if I could blink the on board led using the example @ https://www.ghielectronics.com/docs/112/developersguide-g400-module
So using Visual Studio 2012 professional I created a Micro Framework Console Application project. I then went to the project properties → .NET Micro Framework tab and selected Transport as USB and Device “G400_G400”. Then I set the target framework to “.NET Micro Framework 4.2”. I added the “GHI.Hardware.G400” and “Microsoft.SPOT.Hardware” assemblies.
At this point when I deploy the project I get the following:
Looking for a device on transport ‘USB’
Starting device deployment…
Iteration 0
Opening port \?\usb#vid_1b9f&pid_0102#0000000001#{d32d1d64-963d-463e-874a-8ec8c8082cbf}
Attaching debugger engine…
… debugger engine attached!
Querying device assemblies…
Found Assembly mscorlib 4.2.0.0
Found Assembly Microsoft.SPOT.Native 4.2.0.0
Found Assembly Microsoft.SPOT.Security.PKCS11 4.2.0.0
Found Assembly System.Security 4.2.0.0
Found Assembly Microsoft.SPOT.Hardware 4.2.0.0
Found Assembly Microsoft.SPOT.Graphics 4.2.0.0
Found Assembly Microsoft.SPOT.TinyCore 4.2.0.0
Found Assembly Microsoft.SPOT.IO 4.2.0.0
Found Assembly System.IO 4.2.0.0
Found Assembly Microsoft.SPOT.Hardware.Usb 4.2.0.0
Found Assembly Microsoft.SPOT.Hardware.SerialPort 4.2.0.0
Found Assembly Microsoft.SPOT.Touch 4.2.0.0
Found Assembly Microsoft.SPOT.Ink 4.2.0.0
Found Assembly Microsoft.SPOT.Hardware.PWM 4.2.0.1
Adding pe file C:\NETMF\MFConsoleApplication1\MFConsoleApplication1\bin\Debug\le\MFConsoleApplication1.pe to deployment bundle
Adding pe file C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.2 SDK\Libraries\le\ghi.hardware.g400.pe to deployment bundle
Attempting deployment…
Incrementally deploying assemblies to device
Assemblies not successfully deployed to device.
Deployment to the device was not successful.
Not sure where to go from here, any suggestions on what I need to do or where I went wrong?
