i get this error when trying to use the watchdog on G30TH module:
NETMF Version: v4.3
Device and TinyCLR version: 4.3.8.1
Output:
A first chance exception of type ‘System.InvalidOperationException’ occurred in GHI.Hardware.dll
An unhandled exception of type ‘System.InvalidOperationException’ occurred in GHI.Hardware.dll
Call stack:
TisakG30THK14.exe!TisakG30THK14.Program.Main() Line 47 + 0x41 bytes C#
An example from here http://old.ghielectronics.com/docs/31/watchdog
1st deploy and debug works, every other afterwards throws an exception
then I have to use FEZ config to erase the app so that I can debug again.
found a semi-workaround here:
I have 30 unattended devices rolled out two weeks ago that started freezing, couldn’t get the watchdog to work.
also as a side problem I cannot get the new TinyCLR OS to work on G30TH, I know its still alpha release but the new config tool does not work at all.
So we’re clear and we don’t miss any steps, can you start with a freshly flashed device and list here every step you take that reproduces the exception? Include everything like reset the board, apply power, deploy a given program, and so on.
For other issues you may have, like the TinyCLR OS on G30, that is also best done in it’s own thread.
Connect a fresh device to USB and FEZ config ping it
Select the device in VS
Debug the app
Works OK!
Stop Debug
Start Debug again
Exception!
Only thing that works is:
8.Erase app with FEZ config
9.Disconnect USB
10.Connect USB
11.Debug the app
12.Repeat 8-11 every time
We were able to reproduce the issue with the G30, but we do not have a fix at this time. You may be able to work around it by using the Register class to access the processor watchdog registers directly instead of using our class.
