Why do you need PWM, for the display I mean? You will only copy the display code from the brainpad driver, not the entire driver.
/// <summary>
/// Controls the display on the BrainPad.
/// </summary>
public static class Display {
private static SPI spi;
private static OutputPort controlPin;
private static OutputPort resetPin;
private static OutputPort backlightPin;
private static byte[] buffer1;
private static byte[] buffer2;
private static byte[] buffer4;
private static byte[] clearBuffer;
private static byte[] characterBuffer1;
private static byte[] characterBuffer2;
private static byte[] characterBuffer4;
private const byte ST7735_MADCTL = 0x36;
private const byte MADCTL_MY = 0x80;
private const byte MADCTL_MX = 0x40;
private const byte MADCTL_MV = 0x20;
private const byte MADCTL_BGR = 0x08;
/// <summary>
/// The width of the display in pixels.
/// </summary>
public const int Width = 160;
/// <summary>
/// The height of the display in pixels.
/// </summary>
public const int Height = 128;
static Display() {
buffer1 = new byte[1];
buffer2 = new byte[2];
buffer4 = new byte[4];
clearBuffer = new byte[160 * 2 * 16];
characterBuffer1 = new byte[80];
characterBuffer2 = new byte[320];
characterBuffer4 = new byte[1280];
controlPin = new OutputPort(Peripherals.Display.Control, false);
resetPin = new OutputPort(Peripherals.Display.Reset, false);
backlightPin = new OutputPort(Peripherals.Display.Backlight, true);
spi = new SPI(new SPI.Configuration(Peripherals.Display.ChipSelect, false, 0, 0, false, true, 12000, Peripherals.Display.SpiModule));
Reset();
WriteCommand(0x11); //Sleep exit
Thread.Sleep(120);
// ST7735R Frame Rate
WriteCommand(0xB1);
WriteData(0x01); WriteData(0x2C); WriteData(0x2D);
WriteCommand(0xB2);
WriteCommand(0xB3);
WriteCommand(0xB4); // Column inversion
WriteData(0x07);
// ST7735R Power Sequence
WriteCommand(0xC0);
WriteData(0xA2); WriteData(0x02); WriteData(0x84);
WriteCommand(0xC1); WriteData(0xC5);
WriteCommand(0xC2);
WriteData(0x0A); WriteData(0x00);
WriteCommand(0xC3);
WriteData(0x8A); WriteData(0x2A);
WriteCommand(0xC4);
WriteData(0x8A); WriteData(0xEE);
WriteCommand(0xC5); // VCOM
WriteData(0x0E);
WriteCommand(0x36); // MX, MY, RGB mode
WriteData(MADCTL_MX | MADCTL_MY | MADCTL_BGR);
// ST7735R Gamma Sequence
WriteCommand(0xe0);
WriteData(0x0f); WriteData(0x1a);
WriteData(0x0f); WriteData(0x18);
WriteData(0x2f); WriteData(0x28);
WriteData(0x20); WriteData(0x22);
WriteData(0x1f); WriteData(0x1b);
WriteData(0x23); WriteData(0x37); WriteData(0x00);
WriteData(0x07);
WriteData(0x02); WriteData(0x10);
WriteCommand(0xe1);
WriteData(0x0f); WriteData(0x1b);
WriteData(0x0f); WriteData(0x17);
WriteData(0x33); WriteData(0x2c);
WriteData(0x29); WriteData(0x2e);
WriteData(0x30); WriteData(0x30);
WriteData(0x39); WriteData(0x3f);
WriteData(0x00); WriteData(0x07);
WriteData(0x03); WriteData(0x10);
WriteCommand(0x2a);
WriteData(0x00); WriteData(0x00);
WriteData(0x00); WriteData(0x7f);
WriteCommand(0x2b);
WriteData(0x00); WriteData(0x9f);
WriteCommand(0xF0); //Enable test command
WriteData(0x01);
WriteCommand(0xF6); //Disable ram power save mode
WriteData(0x00);
WriteCommand(0x3A); //65k mode
WriteData(0x05);
// Rotate
WriteCommand(ST7735_MADCTL);
WriteData(MADCTL_MV | MADCTL_MY);
WriteCommand(0x29); //Display on
Thread.Sleep(50);
Clear();
private static void WriteData(byte[] data) {
controlPin.Write(true);
spi.Write(data);
private static void WriteCommand(byte command) {
buffer1[0] = command;
controlPin.Write(false);
spi.Write(buffer1);
private static void WriteData(byte data) {
buffer1[0] = data;
spi.Write(buffer1);
private static void Reset() {
resetPin.Write(false);
Thread.Sleep(300);
resetPin.Write(true);
Thread.Sleep(1000);
private static void SetClip(int x, int y, int width, int height) {
WriteCommand(0x2A);
buffer4[1] = (byte)x;
buffer4[3] = (byte)(x + width - 1);
spi.Write(buffer4);
WriteCommand(0x2B);
buffer4[1] = (byte)y;
buffer4[3] = (byte)(y + height - 1);
spi.Write(buffer4);
/// <summary>
/// Clears the Display.
/// </summary>
public static void Clear() {
SetClip(0, 0, 160, 128);
WriteCommand(0x2C);
for (var i = 0; i < 128 / 16; i++)
WriteData(clearBuffer);
/// <summary>
/// Draws an image.
/// </summary>
/// <param name="data">The image as a byte array.</param>
public static void DrawImage(byte[] data) {
if (data == null) throw new ArgumentNullException("data");
if (data.Length == 0) throw new ArgumentException("data.Length must not be zero.", "data");
WriteCommand(0x2C);
WriteData(data);
/// <summary>
/// Draws an image at the given location.
/// </summary>
/// <param name="x">The x coordinate to draw at.</param>
/// <param name="y">The y coordinate to draw at.</param>
/// <param name="image">The image to draw.</param>
public static void DrawImage(int x, int y, Image image) {
if (image == null) throw new ArgumentNullException("image");
if (x < 0) throw new ArgumentOutOfRangeException("x", "x must not be negative.");
if (y < 0) throw new ArgumentOutOfRangeException("y", "y must not be negative.");
SetClip(x, y, image.Width, image.Height);
DrawImage(image.Pixels);
/// <summary>
/// Draws a filled rectangle.
/// </summary>
/// <param name="width">The width of the rectangle.</param>
/// <param name="height">The height of the rectangle.</param>
/// <param name="color">The color to draw.</param>
public static void DrawFilledRectangle(int x, int y, int width, int height, Color color) {
if (width < 0) throw new ArgumentOutOfRangeException("width", "width must not be negative.");
if (height < 0) throw new ArgumentOutOfRangeException("height", "height must not be negative.");
SetClip(x, y, width, height);
var data = new byte[width * height * 2];
for (var i = 0; i < data.Length; i += 2) {
data[i] = (byte)((color.As565 >> 8) & 0xFF);
data[i + 1] = (byte)((color.As565 >> 0) & 0xFF);
DrawImage(data);
/// <summary>
/// Turns the backlight on.
/// </summary>
public static void TurnOn() {
backlightPin.Write(true);
/// <summary>
/// Turns the backlight off.
/// </summary>
public static void TurnOff() {
backlightPin.Write(false);
/// <summary>
/// Draws a pixel.
/// </summary>
public static void SetPixel(int x, int y, Color color) {
SetClip(x, y, 1, 1);
buffer2[0] = (byte)(color.As565 >> 8);
buffer2[1] = (byte)(color.As565 >> 0);
DrawImage(buffer2);
/// <summary>
/// Draws a line.
/// </summary>
/// <param name="x">The x coordinate to start drawing at.</param>
/// <param name="y">The y coordinate to start drawing at.</param>
/// <param name="x1">The ending x coordinate.</param>
/// <param name="y1">The ending y coordinate.</param>
public static void DrawLine(int x0, int y0, int x1, int y1, Color color) {
if (x0 < 0) throw new ArgumentOutOfRangeException("x0", "x0 must not be negative.");
if (y0 < 0) throw new ArgumentOutOfRangeException("y0", "y0 must not be negative.");
if (x1 < 0) throw new ArgumentOutOfRangeException("x1", "x1 must not be negative.");
if (y1 < 0) throw new ArgumentOutOfRangeException("y1", "y1 must not be negative.");
var steep = Math.Abs(y1 - y0) > Math.Abs(x1 - x0);
int t, dX, dY, yStep, error;
if (steep) {
t = x0;
x0 = y0;
y0 = t;
t = x1;
x1 = y1;
y1 = t;
if (x0 > x1) {
t = x0;
x0 = x1;
x1 = t;
t = y0;
y0 = y1;
y1 = t;
dX = x1 - x0;
dY = System.Math.Abs(y1 - y0);
error = (dX / 2);
if (y0 < y1) {
yStep = 1;
else {
yStep = -1;
for (; x0 < x1; x0++) {
if (steep) {
SetPixel(y0, x0, color);
else {
SetPixel(x0, y0, color);
error -= dY;
if (error < 0) {
y0 += (byte)yStep;
error += dX;
/// <summary>
/// Draws a circle.
/// </summary>
/// <param name="r">The radius of the circle.</param>
public static void DrawCircle(int x, int y, int r, Color color) {
if (r <= 0) throw new ArgumentOutOfRangeException("radius", "radius must be positive.");
int f = 1 - r;
int ddFX = 1;
int ddFY = -2 * r;
int dX = 0;
int dY = r;
SetPixel(x, y + r, color);
SetPixel(x, y - r, color);
SetPixel(x + r, y, color);
SetPixel(x - r, y, color);
while (dX < dY) {
if (f >= 0) {
dY--;
ddFY += 2;
f += ddFY;
dX++;
ddFX += 2;
f += ddFX;
SetPixel(x + dX, y + dY, color);
SetPixel(x - dX, y + dY, color);
SetPixel(x + dX, y - dY, color);
SetPixel(x - dX, y - dY, color);
SetPixel(x + dY, y + dX, color);
SetPixel(x - dY, y + dX, color);
SetPixel(x + dY, y - dX, color);
SetPixel(x - dY, y - dX, color);
/// <summary>
/// Draws a rectangle.
/// </summary>
/// <param name="color">The color to use.</param>
public static void DrawRectangle(int x, int y, int width, int height, Color color) {
for (var i = x; i < x + width; i++) {
SetPixel(i, y, color);
SetPixel(i, y + height - 1, color);
for (var i = y; i < y + height; i++) {
SetPixel(x, i, color);
SetPixel(x + width - 1, i, color);
static byte[] font = new byte[95 * 5] {
0x00, 0x00, 0x00, 0x00, 0x00, /* Space 0x20 */
0x00, 0x00, 0x4f, 0x00, 0x00, /* ! */
0x00, 0x07, 0x00, 0x07, 0x00, /* " */
0x14, 0x7f, 0x14, 0x7f, 0x14, /* # */
0x24, 0x2a, 0x7f, 0x2a, 0x12, /* $ */
0x23, 0x13, 0x08, 0x64, 0x62, /* % */
0x36, 0x49, 0x55, 0x22, 0x20, /* & */
0x00, 0x05, 0x03, 0x00, 0x00, /* ' */
0x00, 0x1c, 0x22, 0x41, 0x00, /* ( */
0x00, 0x41, 0x22, 0x1c, 0x00, /* ) */
0x14, 0x08, 0x3e, 0x08, 0x14, /* // */
0x08, 0x08, 0x3e, 0x08, 0x08, /* + */
0x50, 0x30, 0x00, 0x00, 0x00, /* , */
0x08, 0x08, 0x08, 0x08, 0x08, /* - */
0x00, 0x60, 0x60, 0x00, 0x00, /* . */
0x20, 0x10, 0x08, 0x04, 0x02, /* / */
0x3e, 0x51, 0x49, 0x45, 0x3e, /* 0 0x30 */
0x00, 0x42, 0x7f, 0x40, 0x00, /* 1 */
0x42, 0x61, 0x51, 0x49, 0x46, /* 2 */
0x21, 0x41, 0x45, 0x4b, 0x31, /* 3 */
0x18, 0x14, 0x12, 0x7f, 0x10, /* 4 */
0x27, 0x45, 0x45, 0x45, 0x39, /* 5 */
0x3c, 0x4a, 0x49, 0x49, 0x30, /* 6 */
0x01, 0x71, 0x09, 0x05, 0x03, /* 7 */
0x36, 0x49, 0x49, 0x49, 0x36, /* 8 */
0x06, 0x49, 0x49, 0x29, 0x1e, /* 9 */
0x00, 0x36, 0x36, 0x00, 0x00, /* : */
0x00, 0x56, 0x36, 0x00, 0x00, /* ; */
0x08, 0x14, 0x22, 0x41, 0x00, /* < */
0x14, 0x14, 0x14, 0x14, 0x14, /* = */
0x00, 0x41, 0x22, 0x14, 0x08, /* > */
0x02, 0x01, 0x51, 0x09, 0x06, /* ? */
0x3e, 0x41, 0x5d, 0x55, 0x1e, /* @ 0x40 */
0x7e, 0x11, 0x11, 0x11, 0x7e, /* A */
0x7f, 0x49, 0x49, 0x49, 0x36, /* B */
0x3e, 0x41, 0x41, 0x41, 0x22, /* C */
0x7f, 0x41, 0x41, 0x22, 0x1c, /* D */
0x7f, 0x49, 0x49, 0x49, 0x41, /* E */
0x7f, 0x09, 0x09, 0x09, 0x01, /* F */
0x3e, 0x41, 0x49, 0x49, 0x7a, /* G */
0x7f, 0x08, 0x08, 0x08, 0x7f, /* H */
0x00, 0x41, 0x7f, 0x41, 0x00, /* I */
0x20, 0x40, 0x41, 0x3f, 0x01, /* J */
0x7f, 0x08, 0x14, 0x22, 0x41, /* K */
0x7f, 0x40, 0x40, 0x40, 0x40, /* L */
0x7f, 0x02, 0x0c, 0x02, 0x7f, /* M */
0x7f, 0x04, 0x08, 0x10, 0x7f, /* N */
0x3e, 0x41, 0x41, 0x41, 0x3e, /* O */
0x7f, 0x09, 0x09, 0x09, 0x06, /* P 0x50 */
0x3e, 0x41, 0x51, 0x21, 0x5e, /* Q */
0x7f, 0x09, 0x19, 0x29, 0x46, /* R */
0x26, 0x49, 0x49, 0x49, 0x32, /* S */
0x01, 0x01, 0x7f, 0x01, 0x01, /* T */
0x3f, 0x40, 0x40, 0x40, 0x3f, /* U */
0x1f, 0x20, 0x40, 0x20, 0x1f, /* V */
0x3f, 0x40, 0x38, 0x40, 0x3f, /* W */
0x63, 0x14, 0x08, 0x14, 0x63, /* X */
0x07, 0x08, 0x70, 0x08, 0x07, /* Y */
0x61, 0x51, 0x49, 0x45, 0x43, /* Z */
0x00, 0x7f, 0x41, 0x41, 0x00, /* [ */
0x02, 0x04, 0x08, 0x10, 0x20, /* \ */
0x00, 0x41, 0x41, 0x7f, 0x00, /* ] */
0x04, 0x02, 0x01, 0x02, 0x04, /* ^ */
0x40, 0x40, 0x40, 0x40, 0x40, /* _ */
0x00, 0x00, 0x03, 0x05, 0x00, /* ` 0x60 */
0x20, 0x54, 0x54, 0x54, 0x78, /* a */
0x7F, 0x44, 0x44, 0x44, 0x38, /* b */
0x38, 0x44, 0x44, 0x44, 0x44, /* c */
0x38, 0x44, 0x44, 0x44, 0x7f, /* d */
0x38, 0x54, 0x54, 0x54, 0x18, /* e */
0x04, 0x04, 0x7e, 0x05, 0x05, /* f */
0x08, 0x54, 0x54, 0x54, 0x3c, /* g */
0x7f, 0x08, 0x04, 0x04, 0x78, /* h */
0x00, 0x44, 0x7d, 0x40, 0x00, /* i */
0x20, 0x40, 0x44, 0x3d, 0x00, /* j */
0x7f, 0x10, 0x28, 0x44, 0x00, /* k */
0x00, 0x41, 0x7f, 0x40, 0x00, /* l */
0x7c, 0x04, 0x7c, 0x04, 0x78, /* m */
0x7c, 0x08, 0x04, 0x04, 0x78, /* n */
0x38, 0x44, 0x44, 0x44, 0x38, /* o */
0x7c, 0x14, 0x14, 0x14, 0x08, /* p 0x70 */
0x08, 0x14, 0x14, 0x14, 0x7c, /* q */
0x7c, 0x08, 0x04, 0x04, 0x00, /* r */
0x48, 0x54, 0x54, 0x54, 0x24, /* s */
0x04, 0x04, 0x3f, 0x44, 0x44, /* t */
0x3c, 0x40, 0x40, 0x20, 0x7c, /* u */
0x1c, 0x20, 0x40, 0x20, 0x1c, /* v */
0x3c, 0x40, 0x30, 0x40, 0x3c, /* w */
0x44, 0x28, 0x10, 0x28, 0x44, /* x */
0x0c, 0x50, 0x50, 0x50, 0x3c, /* y */
0x44, 0x64, 0x54, 0x4c, 0x44, /* z */
0x08, 0x36, 0x41, 0x41, 0x00, /* { */
0x00, 0x00, 0x77, 0x00, 0x00, /* | */
0x00, 0x41, 0x41, 0x36, 0x08, /* } */
0x08, 0x08, 0x2a, 0x1c, 0x08 /* ~ */
private static void DrawLetter(int x, int y, char letter, Color color, int scaleFactor) {
var index = 5 * (letter - 32);
var upper = (byte)(color.As565 >> 8);
var lower = (byte)(color.As565 >> 0);
var characterBuffer = scaleFactor == 1 ? characterBuffer1 : (scaleFactor == 2 ? characterBuffer2 : characterBuffer4);
var i = 0;
for (var j = 1; j <= 64; j *= 2) {
for (var k = 0; k < scaleFactor; k++) {
for (var l = 0; l < 5; l++) {
for (var m = 0; m < scaleFactor; m++) {
var show = (font[index + l] & j) != 0;
characterBuffer[i++] = show ? upper : (byte)0x00;
characterBuffer[i++] = show ? lower : (byte)0x00;
SetClip(x, y, 5 * scaleFactor, 8 * scaleFactor);
DrawImage(characterBuffer);
/// <summary>
/// Draws a letter at the given location.
/// </summary>
/// <param name="letter">The letter to draw.</param>
public static void DrawLetter(int x, int y, char letter, Color color) {
if (letter > 126 || letter < 32) throw new ArgumentOutOfRangeException("letter", "This letter cannot be drawn.");
DrawLetter(x, y, letter, color, 1);
/// <summary>
/// Draws a large letter at the given location.
/// </summary>
public static void DrawLargeLetter(int x, int y, char letter, Color color) {
DrawLetter(x, y, letter, color, 2);
/// <summary>
/// Draws an extra large letter at the given location.
/// </summary>
public static void DrawExtraLargeLetter(int x, int y, char letter, Color color) {
DrawLetter(x, y, letter, color, 4);
/// <summary>
/// Draws text at the given location.
/// </summary>
/// <param name="text">The string to draw.</param>
public static void DrawText(int x, int y, string text, Color color) {
if (text == null) throw new ArgumentNullException("data");
for (var i = 0; i < text.Length; i++)
DrawLetter(x + i * 6, y, text[i], color, 1);
/// <summary>
/// Draws large text at the given location.
/// </summary>
public static void DrawLargeText(int x, int y, string text, Color color) {
DrawLetter(x + i * 6 * 2, y, text[i], color, 2);
/// <summary>
/// Draws extra large text at the given location.
/// </summary>
public static void DrawExtraLargeText(int x, int y, string text, Color color) {
DrawLetter(x + i * 6 * 4, y, text[i], color, 4);
/// <summary>
/// Draws a number at the given location.
/// </summary>
/// <param name="number">The number to draw.</param>
public static void DrawNumber(int x, int y, double number, Color color) {
DrawText(x, y, number.ToString("N2"), color);
/// <summary>
/// Draws a large number at the given location.
/// </summary>
public static void DrawLargeNumber(int x, int y, double number, Color color) {
DrawLargeText(x, y, number.ToString("N2"), color);
/// <summary>
/// Draws an extra large number at the given location.
/// </summary>
public static void DrawExtraLargeNumber(int x, int y, double number, Color color) {
DrawExtraLargeText(x, y, number.ToString("N2"), color);
/// <summary>
/// </summary>
public static void DrawNumber(int x, int y, long number, Color color) {
DrawText(x, y, number.ToString("N0"), color);
/// <summary>
/// </summary>
public static void DrawLargeNumber(int x, int y, long number, Color color) {
DrawLargeText(x, y, number.ToString("N0"), color);
/// <summary>
/// </summary>
public static void DrawExtraLargeNumber(int x, int y, long number, Color color) {
DrawExtraLargeText(x, y, number.ToString("N0"), color);
