Hi Guys,
Does anybody know where I can find a pin out reference for the GXP connector on the G120TH module?
I searched the forum and found a post about the “NEW GXP Standard” which linked to this document:
https://www.ghielectronics.com/downloads/man/GXP%20Pinout.pdf
but it looks like it is no longer available.
The schematic should have all the pinout information you need
Thanks John,
Id been looking at that but I thought the spec might have included some extra explanatory information.
I’m trying to wire up an Adafruit 40-pin TFT Friend breakout to the GXP header and this is what I’ve come up with so far:
Do you know if
- GXP LCD.Enable is the same as Data Enabled
- Is ON/OFF just supposed to be connected to any GPIO pin?
Thanks,
David
LCD.Enable is DE.
If ON/OFF is a simple switch, any extra GPIO should be fine.
