Hi all, I’m making the pin mapping for our PCB and i see that P0.5 used for CAN2 TD also should be used for the ENC28 INT input… I need both
Possible?
You can use any interrupt capable pin for enc28 int pin.
I see it now, it’s passed as a parameter in EthernetENC28J60, thanks Gus.
