I have updated my G120HDR to latest firmware with the updater, deployed my app and started to debug.
After 80 seconds the debug hangs when stepping in the code, this freeze is released with a reboot from the G120 (I hear sound of USB is unplugged).
Then the G120 reconnects over USB but it impossible to deploy again because the G120 is rebooting every 80 second.
The only way to get VS2010 connected to G120 is to do an firmware update.
Any idea what could cause this behaviour??
In my code I load an internal resource file and load it to a Stream.
Sounds like your code is going into a tight loop, which makes it difficult for the debugger to attach to your running program.
This could also be caused by your program throwing an unhandled exception.
Without seeing code displaying the problem, it is difficult to determine what is happening.
