Hi, I will connect the CP7 display to the G120HDR, so Red/Green/Blue is obvious how to connect, but the I Socket is a little bit confusing.
In the schematics i see the SDA and SCL, ok they get to P0.27 and P0.28, but whats with the INT and RST pins? Are they importent? I think they are not connected at the display?
Further, when all is working, is there some code to Initialize the touchscreen? I do not use gadgeteer, only normal netmf.
Best regards
