I have worked with G120HDR 2,0 board for a while, and with good experience. This morning I unfortunately got some problems, which I have been unable to solve.
I have tried to reinstall the Firmware(“sucess” according FEZ config)
But still can not program the G120HDR.
FEZ config:
[quote] Connecting to device G120_g120.
Please wait, this may take a few moments
Failure - Device is not connected or not responding.[/quote]
I can only connect to boadet in
[quote]LDR0 LDR1 Boot Access
X High Firmware (TinyCLR) [/quote]
It seems like it loses its configuration:
[quote] Loader (TinyBooter) version information:
4.2.11.1 on this computer.
4.2.11.0 on this device.
The >>> Loader (TinyBooter) not up to date. <<<
Firmware (TinyCLR) version information:
Firmware (TinyCLR) Version: Not available.
The device is in Loader mode.
Click on ‘Reboot CLR’ under the Advanced menu two reboot the device.[/quote]
I use win7x64 but this is not the problem. This G120 board has the same problem on other PCs. I can program other G120 on my pc :think:
[quote]
The Loader (TinyBooter) not up to date. <<<
Click on ‘Reboot CLR’ under the Advanced menu to reboot the device.[/quote]
Check your power supply anyway.
I had a Cobra II that was booting extremely slow and acted wired sometimes.
Then I changed my extra power supply and now it’s back to normal.
The ‘bad’ power supply worked without problems on a different Cobra II before.
But I was to lazy to do the counter check so far.
Power supply is indeed the first thing to look at, i had some incredibly strange issues in the past that where 100% reproducible but at the end where related to power issues.
Next thing to keep in mind is, is this issue related to deploying a new version off your software? i had problems like a 100 times after deploying new software changes and had to get back to reflashing everything to get up and running again.
Or at least deploying software during a hard reset to get the board responsive for deployment.
I have measured with oscilloscope and the supply is 3v3 + / - 100mV_pp at 3v3 pin
@ Dat
[quote]@ Larsc -
Try to update TinyBooter + Firmware, on FEZ Config, Advanced -> Loader -> G120[/quote]
There are comming an error when using “loader” (pic1) I only have 1 device connected.
@ David@ Emrol
[quote]… had to get back to reflashing everything to get up and running again.
Or at least deploying software during a hard reset to get the board responsive for deployment.[/quote]
Reflashing… how is this done?
I worked with PWM driver and setup of PWM 8 when the error occurred. I think the pwm driver are causing the Error. Are there anyway to make a complete reboot and re-install the G120hdr board?
“complete reboot” is just to reflash it - the process you’re partially getting into. To do this you just need to boot into bootloader mode, reapply the bootloader and then firmware (will wipe your app). Then you’ll have a fresh device.
[quote]“complete reboot” is just to reflash it - the process you’re partially getting into. To do this you just need to boot into bootloader mode, reapply the bootloader and then firmware (will wipe your app). Then you’ll have a fresh device.
