Does anyone have T35 and touch working on a G120 - if so any chance of some sample code and wiring requirments?
Mike
Mike
It works in cobra which is based on G120. Take a look at the gadgeteer driver.
Have a look at the G120GDR, this one has the sockets wired as you need then:
@ michaelo -
I also have a simple example code to test Touch,
Before deploy them, use FEZ config to config the T35 LCD screen!
using Microsoft.SPOT.Touch;
using Microsoft.SPOT.Input;
using Microsoft.SPOT.IO;
using GHI.Premium.Hardware;
namespace G400_TestTouch
public class Program : Microsoft.SPOT.Application
public static Bitmap bmp = new Bitmap(320, 240);
static Program myDisplayTestApp;
if (SystemMetrics.ScreenHeight == 0 || SystemMetrics.ScreenWidth == 0)
Debug.Print("Use FEZ config to config the T35 LCD screen!");
myDisplayTestApp = new Program();
Microsoft.SPOT.Touch.Touch.Initialize(myDisplayTestApp);
myDisplayTestApp.MainWindow = new Microsoft.SPOT.Presentation.Window();
myDisplayTestApp.MainWindow.TouchDown += new TouchEventHandler(MainWindow_TouchDown);
myDisplayTestApp.MainWindow.TouchUp += new TouchEventHandler(MainWindow_TouchUp);
myDisplayTestApp.Run();
static void MainWindow_TouchUp(object sender, TouchEventArgs e)
Debug.Print("X: " + e.Touches[0].X + " Y: " + e.Touches[0].Y);
bmp.DrawText("(" + e.Touches[0].X + "," + e.Touches[0].Y + ")", Resources.GetFont(Resources.FontResources.NinaB),
Colors.Green, e.Touches[0].X, e.Touches[0].Y);
bmp.Flush();
static void MainWindow_TouchDown(object sender, TouchEventArgs e)
bmp.Clear();
Colors.Red, e.Touches[0].X, e.Touches[0].Y);
bmp.Flush();
