So my question for GHI and anyone that could offer some light is:
If we get the same Ethernet PHY chip from the G120E, can we use the existing drivers on our existing G120?
Can someone share how can we connect this chip to a regular G120 to make the GHI built in driver for .Net framework work (pin wise)?
I’m not asking for the G120E schematics just for a sample pin out with this PHY chip to work with a G120 using the GHI existing drivers or maybe a way to reuse the existing Ethernet builtin code with the G120 and the Ethernet PHY chip because it was already done for the G120E.
Hopefully I won’t need to develop a driver from scratch and be able to get some of the already tested and bullet-proof code from GHI into the Ethernet controller.
In theory yes it will work and you do not need a driver. This was not tested. What I suggest is that you work with our consulting on getting this together for you. A safer route and probably cheaper than trial and error.
Great @ Gus !
You guys are awesome.
I will get in touch as soon as we finish the requirement, at least we have the critical path covered.
Do you mind sharing the email of the right person to contact about this?
