Hi all,
I would ask if the 7s startup time is normal. I explain:
When I start my cobra II, my program is starting only after 7s. For an embedded system it’s a lot, no ?
:think:
Hi all,
:think:
@ Lionel - Yes its normal. The device is reading from the SPI flash memory at startup.
Ok thx.
@ Lionel -
If you connect by USB then you will see start up time takes 7 seconds.
But if the board runs without USB connected then it just take about 2 seconds.
Or if the board has an application already then it also take about 2 seconds.
You can deploy simple application with blink LED then you will see.
Meaning 7 seconds is only when the board is empty (no C# application) and USB debugger is connected to PC.
That was 4.3 normal behavior, but it is corrected in our new TinyCLR.
