Hi All,
I am trying to connect G120 to my HTC Windows Phone 8 by Wifi and run HttpListener on G120. My first intention was to turn on the Ad-hoc on RS9110. Unfortunately, it appeared that the Windows phone does not see ad-hoc connections. And RS9110 cannot provide a hot-spot.
Next idea was to share the internet from a telephone. At a first glance it worked. G120 was able to see the network provided by the phone and connect to it. However, it was not able to transmit/receive any data. The same thing was happened with a PC: ping failed to any addresses, including 192.168.137.1 - the phone itself. As I found in the web, enabling “Use FIPS” checkbox in the advanced network settings solved the problem for the PC. But looks like the way RS9110 works is not compatible with FIPS.
Also, as I found in Windows Phone forums, this problem is kind of common for many, if not all of Windows 8 phones, regardless of the manufacturer.
Had anyone ran into this issue? Is there a workaround available? Or, probably, are there there any other wifi transceivers to try?
