I’m simply trying to connect to my Terminal on my computer via the Cobra II. I have dug around for code samples and this is what I have come up with as what " I think" is right. The serial port initializes and the loop sits and “counts” to the debug.print. But nothing is showing up on my PC Terminal program. I guess I’m at a loss as to figure out how to debug this…
G120 board, with a RS232 v1.1 module plugged into socket 5 (U X?). Program runs regardless of weather the module is plugged in or not. I’m using a serial cable plugged directly into COM1 on my computer. I know my computer works because I have attached it to other “RS232” sources and I can see info in the terminal.
I’m powering my board via the small USB power port. Could this be the problem? Does GHI sell a power supply for this board? Seems like I have not seen one?
Can anyone point me in a direction???
private static void TestSerial()
MainBoard = new GHIElectronics.Gadgeteer.FEZCobra_II();
Gadgeteer.Modules.GHIElectronics.RS232 sp = new Gadgeteer.Modules.GHIElectronics.RS232(5);
sp.Initialize(9600, GT.Interfaces.Serial.SerialParity.None, GT.Interfaces.Serial.SerialStopBits.One, 8, GT.Interfaces.Serial.HardwareFlowControl.NotRequired);
int counter = 0;
sp.serialPort.Open();
Debug.Print(sp.serialPort.IsOpen.ToString());
// create a string
string counter_string = "Count: " + counter.ToString() + "\r\n";
// convert the string to bytes
byte[] buffer = Encoding.UTF8.GetBytes(counter_string);
// send the bytes on the serial port
sp.serialPort.Write(buffer, 0, buffer.Length);
// increment the counter;
counter++;
//wait...
Debug.Print(counter.ToString());
Thread.Sleep(100);
The program could look like this if you used the designer. It works.
@ Mike - Sorry, you are right of course. It was only a 5 minute test to see if the port works.
is this o.k.?
using System.Collections;
using System.Text;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace TestSerialPort
public partial class Program
rs232.Initialize(9600, GT.Interfaces.Serial.SerialParity.None, GT.Interfaces.Serial.SerialStopBits.One, 8, GT.Interfaces.Serial.HardwareFlowControl.NotRequired);
Thread WriteThread = new Thread(WriteToComPort);
WriteThread.Start();
private void WriteToComPort()
int counter = 0;
rs232.serialPort.Open();
Debug.Print(rs232.serialPort.IsOpen.ToString());
// create a string
rs232.serialPort.Write(buffer, 0, buffer.Length);
counter++;
//wait...
Thread.Sleep(100);
@ Dan Harris, can you tell us about the PC end of this connection? The RS232 module has a DB9 output, are you connecting to a “real” serial port with a DB9, or are you using a USB/RS232 converter? Also, can you confirm you’re using the right baud rate?
I would not use a while loop when I’m done. Just trying to get something to show up on the PC before I get to deep. (Baby steps)
I have a 9 pin serial cable directly to my computer, which has a good old fashion 9 pin Com port on it. I assume it is a straight thru cable, but doesn’t say so directly on package.
Yes on baud rate.
Does it “really” matter if I’m not running this simple example in a thread? I mean all I’m looking for is something to show up in the terminal program.
Thanks for the help so far, I really don’t know how much simpler I could have made this for myself… I must missing something stupid…
OK, so if you have a DB9 on the PC, that’s great. Can you confirm you’ve had devices connected, using that actual cable, to your PC and have been able to send and receive data?
@ Dan Harris - Why do you not use the designer? It is so easy I think. Both examples I posted were ready in a minute and both work, I can see the messages in teraterm.
@ Mike I will delete my first bad example. Perhaps you can delete your post too. I think it’s not necessarry to fill the form with “bad” things.
@ RoSchmi - I do not consider my posting to be a “bad” thing. Connecting two devices with RS-232 has been “fun” area for many many years. All to often the problems are related to the type of cable being used.
