I finally got in my hand a G120HDR rev2 board. It’s running fine, but two question, no gadgeteer use:
1.I used GHI alternate program to set network configuration. It shows 3 settings (Network1,2,3). I’ve changed just Network1 to a fixed IP). Now where I activate the configuration n.1 ? I rimember on the forum a GUS post but I couldn’t find … sigh. (I attached an ENC board to SPI socket).
LCD (good old T35) how can be accessed from programs ? I need all the Presentation.xxx (or Glide) framework or there are some direct write methods (like gadgeteer display) ?
Thank you gus!
I know that I need enc28 and I have connected on g120hdr spi socket. How I setup network configuration? Can I use the ghi software replace for mfdeploy ?
