Hello, I cannot simply send any data to PC, for example:
I have connected the wires to the module’s COM3 on the “extension comb” like follows: p0.11/COM3_Rx0, P0.10/COM3_TX0, GND. I am using a TTL to RS232 converter.
SerialPort serial = new SerialPort(Serial.COM3, 9600, Parity.None, 8, StopBits.One);
serial.Open();
byte[] buf = new byte[] {0x41, 0x42, 0x43};
serial.Write(buf, 0, buf.Length);
serial.Flush();
And I see nothing on the receiving side (PC with hyperterminal). The connection parameters match. I am new to this board and I am not sure whether do I need to pre-configure the pins/dips on G120, or does the framework do it for me? Do I need to set tx to output somehow and rx to input etc?
I had weird behaviour that without the ttl/RS232 converter when I opened the port on the board’s side it sent the byte 0x00, but with it I have no transmission at all.
Thank you in advance
