But on the current release this is stated as “•Low power modes are unimplemented or untested.” in the known issues section? So should hibernate be used on the G120 or not (yet)?
Ok, thank for the confirmation Gus, I’m waiting for the fix before writing the code for this
This should also answer some other active threats in the forum about this subject.
Uh - just noticed this, I didn’t have a watch on it. I was really wondering why Gus said Hibernate was supported on the G120, but untested!
For now I can disable Hibernate with an “if G120” in the code, and just to be sure add a configuration option on SD or EWR so the user can disable it in the field should it be found to have problems on the EMX.
