As all the previous days i want to start and continue my work on a device using the G120.
I did not had much problems with the device since the last firmware update 4.2.11.0
The application in the device has not changed for a few weeks and works as a pipe between com1 and a spi port.
But today it happened again, the device stopped responding. A re-flash of config.hex was necessary to get the device running again. This application does not use Ethernet, its a simple application receiving/sending data from/to com1 and forward it to another device connected to an SPI port.
Scary
