Has anyone tried it.
I am trying to generate the hex file for in-field update
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at Microsoft.NetMicroFramework.Tools.MFDeployTool.Engine.MFApplicationDeployment.CreateDeploymentData(BackgroundWorker backgroundWorker, DoWorkEventArgs doWorkEventArgs) in d:\SD\current\client_v4_3_dev\Framework\Tools\MFDeploy\Library\MFAppDeploy.cs:line 124
at Microsoft.NetMicroFramework.Tools.MFDeployTool.MFAppDeployConfigDialog.OnCreateDeployment_DoWork(Object sender, DoWorkEventArgs e) in d:\SD\current\client_v4_3_dev\Framework\Tools\MFDeploy\Application\MFAppDeployDialog.cs:line 359
at System.ComponentModel.BackgroundWorker.OnDoWork(DoWorkEventArgs e)
at System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object argument)
When this function is called
InFieldUpdate.Load(type, data, BLOCK_SIZE);
There is an exception. Not sure why?
The values are type = 2
and the data is an array of 65K values…so it looks ok
