I have some behavior problems with a custom board based on G120. I like to check if something has changed in firmware once the board behaves strange. For example by calculating a checksum of code memory and compare it with the checksum from an earlier stage… Anyone knows how to do that or how to access the firmware?
The following code does not work because it generates a low level MCU exception at the Read(). might be read protected i guess.
uint sum = 0;
for (var address = 0xf0020000; address < 0xf0120000; address++)
var memPtr = new Register(address);
sum += memPtr.Read();
DebugHelper.DebugPrint("sum=" + sum);
Update 3/10… Solved the issue … if interested see my comment at http://www.tinyclr.com/forum/topic?id=11074&page=4#msg112904
