Hello everyone works with G120 Module,
one week ago, I want using a new hardware based on G120 module. I have get a new G120HDR 1.1 board.
Now I would like make a firmware update form 4.2.4.0 to 4.2.7.0. But after I have made the first four steps in update application
the module couldn’t connect to the PC and the Updater show an error.
Connect to the PC
LDR0 und LDR1 to Low
Reset to Low
LDR0 und LDR1 to High
After this steps no connetion to the PC is possible.
What can I do to restart the boar in the right mode fo updating the fimeware ?
ldr0 and ldr1 to low; reset high, low, high; ldr0 and ldr1 high…
The only thing i’ve seen is an white sreen on the display.
And the device isn’t detected on the PC. After changing the usb port and plug in the cable, only a raw device is detected on the PC ?!?
@ Schmidt - When the device is detected as raw device does G120 updater software not recognize the device? Yesterday i had trouble updating Hydra which was related to installed usb drivers mix up… You could try the approach that worked for me.
1 disconnect device
2. de-installing all GHI software
3. removing all USB drivers using USBdeview.exe
4. manually delete all folders C:\Program files\GHI Electronics
5. Reboot system
6. Install GHI SDK 4.2.8
7. attach device and wait until drivers are installed.
Please tell us exactly what device is shown in Device Manager. In at least the normal boot mode you mention “raw device” so please show us a screen shot of what is visible to DevMgr
so you know in the future (looks like someone has ticked it for you) there’s a little tick-box at the top right of each post, clicking that will tag that answer as the solution
