microt
September 3, 2015, 1:13pm
1
On one of my custom boards I assembled
I soldered the G120 module and it keeps spitting out this below exception on the debug serial port.
The USB is not detected. So I do not know how to proceed
Any help is appreciated
EXCEPTION 0x06:
cpsr=0x1000ff84
pc =0x1000ff60
lr =0x00005001
sp =0x1000dea0
r00 =0x1000de58
r01 =0x00000000
r02 =0x00000001
r03 =0x00001000
r04 =0xa00003d8
r05 =0x00005001
r06 =0x1000ff60
r07 =0x1000ff84
r08 =0xa01390d0
r09 =0x00000020
r10 =0x52b08514
r11 =0x6f146508
r12 =0xa00003d8
@ microt - I imagine you are unable to even get a program on the device? Are you able to put it in loader mode with LDR0 and LDR1?
microt
September 3, 2015, 11:05pm
3
I grounded MODE AND LDR0 and LDR1
and through teraterm loaded tinybooter again.
made LDR0 high
Tinybooter runs.
Then I try to deploy using Visual studio …it fails like below
If I connect termterm. I can see that the exception is coming again
Iteration 0
Opening port \.\COM13
Attaching debugger engine…
… debugger engine attached!
Querying device assemblies…
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.IO.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.pe to deployment bundle
Adding pe file C:\RemoteDrive\Dropbox\Mic-Share\Software\FirmwareSourceCode\Mainboard\G120-1\TouchLogger - AutoClave\TouchLogger\bin\Debug\le\TouchLogger.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Graphics.pe to deployment bundle
Adding pe file C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\ghi.hardware.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.TinyCore.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.pe to deployment bundle
Adding pe file C:\RemoteDrive\Dropbox\Mic-Share\Software\FirmwareSourceCode\Mainboard\G120-1\TouchLogger - AutoClave\ghi_elect-glide\bin\Debug\le\ghi.glide.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\mscorlib.pe to deployment bundle
Adding pe file C:\Program Files (x86)\GHI Electronics.NET Gadgeteer SDK\Modules\DisplayT43\NETMF 4.3\le\gtm.ghielectronics.displayt43.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Touch.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Xml.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\gadgeteer.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.Usb.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.IO.pe to deployment bundle
Adding pe file C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\ghi.sqlite.pe to deployment bundle
Adding pe file C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\ghi.usb.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Native.pe to deployment bundle
Adding pe file C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\ghi.pins.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\MFDpwsExtensions.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.PWM.pe to deployment bundle
Attempting deployment…
Deployment to the device was not successful.
What do you see back when you click the ping button? I have a feeling your device is missing the firmware.
microt
September 4, 2015, 12:18am
5
I updated with FEZ. The update goes ok.
but at the end it is not able to read the version.
And then the exception comes on the serial port
microt
September 5, 2015, 1:50am
6
Right now I have the latest
G120
Version
4.3.7.10 Firmware
4.3.7.7 Loader
And it tells bad firmware after loader update
But I remember a good board having 4.3.1.0.
Is it a version mismatch
@ microt - It looks like your program is pretty big. Can you try to deploy a simple blink LED program?
