I connect my ethernet connection with DHCP -> event is triggered when IP is assigned -> Perfect
Then i change my NetworkInterface to static IP -> NetworkAddressChanged is NOT triggered ?
Is this normal or not? the IP address is changed.
I made a small test program to verify this functionality:
using Microsoft.SPOT.Net;
using GHI.Networking;
using GHI.IO;
using GHI.Pins;
using GHI.Processor;
using GHI.Utilities ;
namespace ethernet
static EthernetENC28J60 MyEthernet;
MyEthernet = new EthernetENC28J60(SPI.SPI_module.SPI2, GHI.Pins.G120.P1_26, GHI.Pins.G120.P0_28);
NetworkChange.NetworkAddressChanged += NetworkChange_NetworkAddressChanged;
NetworkChange.NetworkAvailabilityChanged += NetworkChange_NetworkAvailabilityChanged;
MyEthernet.Open();
MyEthernet.NetworkInterface.EnableDhcp();
MyEthernet.NetworkInterface.EnableDynamicDns();
int _timeout = 0;
while (MyEthernet.NetworkInterface.IPAddress.ToString() == "0.0.0.0")
Thread.Sleep(1000);
_timeout++;
Debug.Print("Ethernet waiting for DHCP");
Debug.Print("Adrress is " + MyEthernet.NetworkInterface.IPAddress.ToString());
if (_timeout > 30)
Debug.Print("Ethernet DHCP timed out after 30 seconds");
MyEthernet.NetworkInterface.EnableStaticIP("192.168.0.1", "255.255.255.0", "192.168.0.1");
break;
while (true )
Thread.Sleep(1000);
static void NetworkChange_NetworkAddressChanged(object sender, EventArgs e)
Debug.Print("Network Address has changed! ");
static void NetworkChange_NetworkAvailabilityChanged(object sender, Microsoft.SPOT.Net.NetworkInformation.NetworkAvailabilityEventArgs e)
Debug.Print("Network has changed! ");
Scenario 1 connect cable to router
Adrress is 0.0.0.0
Adrress is 0.0.0.0
Adrress is 0.0.0.0
Network has changed! <<<---- connect cable
Network Address has changed! <<<---- event fires
Adrress is 10.40.5.22
Network has changed! <<<<---- disconnect cable
Network Address has changed! <<<<---- event fires
Adrress is 0.0.0.0
Adrress is 0.0.0.0
Adrress is 0.0.0.0
Scenario 2 no connection, fallback to fixed IP address
Adrress is 0.0.0.0
Adrress is 0.0.0.0
Adrress is 0.0.0.0
Adrress is 192.168.0.1 <<<---- no event is firing
Network has changed! <<<---- cable connected
Network Address has changed! <<<---- now is the event fired
Adrress is 192.168.0.1 (but address is changed long before this)
This shows me that the event is actualy binded to cable connect?
I think it just has a conditional - if the cable is connected AND the address changes, then it is a real change. If the cable isn’t connected it doesn’t count. I actually think that makes sense - you don’t want to act on the address change if the cable isn’t connected, for example you don’t want to try to go and get the time from the network…
