G120 does no more respond over USB
@ Mike - I did install new pre-release version of SDK and tried it. I still get same issue as before :
Found debugger!
Create TS.
Loading start at a0e6938c, end a0e98820
Assembly: mscorlib (4.3.1.0) Assembly: Microsoft.SPOT.Native (4.3.1.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.3
.1.0) Assembly: System.Security (4.3.1.0) Assembly: Microsoft.SPOT.Hardware (4.3.1.0)
Assembly: Microsoft.SPOT.Graphics (4.3.1.0) Assembly: Microsoft.SPOT.TinyCore (4.3.1.0)
Assembly: Microsoft.SPOT.IO (4.3.1.0) Assembly: System.IO (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.3.1.0) Assembly: Microsoft.SPOT.Touch (4.3.1.0)
Assembly: Microsoft.SPOT.Ink (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.3.1.0)
Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.3.1.0) Attaching deployed file.
Assembly: GHI.Hardware (4.3.7.7) Attaching deployed file.
Assembly: mfnet.smallbiz.common (1.0.0.0) Attaching deployed file.
Assembly: System.Http (4.3.1.0) Attaching deployed file.
Assembly: GHI.Glide (4.3.7.7) Attaching deployed file.
Assembly: Microsoft.SPOT.Time (4.3.1.0) Attaching deployed file.
Assembly: System (4.3.1.0) Attaching deployed file.
Assembly: System.Xml (4.3.1.0) Attaching deployed file.
Assembly: Toolbox.NETMF.Core (4.3.0.0) Attaching deployed file.
Assembly: System.Net.Security (4.3.1.0) Attaching deployed file.
Assembly: GHI.SQLite (4.3.7.7) Attaching deployed file.
Assembly: GHI.Usb (4.3.7.7) Attaching deployed file.
Assembly: powercloud (1.0.0.0) Attaching deployed file.
Assembly: GHI.Pins (4.3.7.7) Attaching deployed file.
Assembly: Microsoft.SPOT.Hardware.OneWire (4.3.1.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net.Security (4.3.1.0) Attaching deployed file.
Assembly: GHI.Networking (4.3.7.7) Resolving.
GC: 1msec 751872 bytes used, 6587796 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 6587796 bytes
Type 17 (ASSEMBLY ): 47220 bytes
Type 1E (BINARY_BLOB_HEAD ): 704556 bytes
GC: performing heap compaction…
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Security.PKCS11.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Graphics.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.TinyCore.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Touch.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Ink.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\NETMF v4.3 SDK\Libraries\le\GHI.Hardware.dll’
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\data\tfs\zigbox\mfnet.smallbiz.common\bin\Debug\le\mfnet.smallbiz.common.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Net.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Http.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Xml.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\NETMF v4.3 SDK\Libraries\le\GHI.Glide.dll’
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Time.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Netmftoolbox.com.NET Micro Framework Toolbox\Assemblies\v4.3\le\Toolbox.NETMF.Core.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\NETMF v4.3 SDK\Libraries\le\GHI.SQLite.dll’
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\NETMF v4.3 SDK\Libraries\le\GHI.Usb.dll’
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.OneWire.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\NETMF v4.3 SDK\Libraries\le\GHI.Networking.dll’
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\data\tfs\zigbox\intelliBin\bin\Debug\le\powercloud.exe’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\NETMF v4.3 SDK\Libraries\le\GHI.Pins.dll’
#### Exception GHI.Networking.WiFiRS9110+HardwareTimeoutException - 0x00000000 (2) ####
#### Message:
#### GHI.Networking.WiFiRS9110::WaitOn [IP: 0012] ####
#### GHI.Networking.WiFiRS9110::UpdateInternalMacAddress [IP: 0025] ####
#### powercloud.Program::.cctor [IP: 00be] ####
Upgrading…
Upgrading…
@ Akshay - It can take several minutes for the upgrade process to complete. How long do you let it run for?
@ John - I ran more than 2 minutes, now on following line it shows error as shows in image1.
wifi = new WiFiRS9110(SPI.SPI_module.SPI2, GHI.Pins.G120.P1_27, GHI.Pins.G120.P2_13, GHI.Pins.G120.P1_28, 4000);
Don’t worry , my pin configuration was wrong, I fixed it now…
