recently found my long lost G400HDR breakout with G400D module, from all the information i found on the forum i still don’t understand what pins i need to connect if i want to be able to program is using VS IDE
connection to PC will be USB but what other pins i need to connect and how?
thanks, this i understand but what if i don’t have it? can i work with soldering and pins to achieve that? if so then what are the pins? what do i need to do so that device will boot into USB mode and allow programming
assuming i have such a device (FTDI) what pins do i need to connect? both for power and for usb/serial, tried several options according to my understanding on the manual but all failed, the best i got is “unrecognized usb device”
this was my initial though (USB cable connecting) but i connected it to USBA_P, USBA_N pins
what about the power? do i need both 3.v and 5v? and to which pins is best connect to?
i don’t have time to purchase a power module right now for the immediate need i have, and it seems like you are talking about sockets and i wanted to use the HDR breakout, do you have any insights on that setup?
where can i find the correct and updated pinout table of the HDR breakout?
