hi,
i have implemented an ftp downloader class from the source code of Jaimon Mathew .
i just ported login and download functions , so you can implement other features
using System.IO;
using GHIElectronics.NETMF.Net.Sockets;
using System.Text;
namespace smg.ftp
public class FtpClient
public class FtpException : Exception
public FtpException(string message) : base(message) { }
public FtpException(string message, Exception innerException) : base(message, innerException) { }
private static int BUFFER_SIZE = 2048;// 512;
private static Encoding ASCII = Encoding.UTF8;
private bool verboseDebugging = false;
// defaults
private string server = "localhost";
private string remotePath = ".";
private string username = "anonymous";
private string password = "anonymous@ anonymous.net";
private string message = null;
private string result = null;
private int port = 21;
private int bytes = 0;
private int resultCode = 0;
private bool loggedin = false;
private bool binMode = false;
private Byte[] buffer = new Byte[BUFFER_SIZE];
private Socket clientSocket = null;
private int timeoutSeconds = 300;
/// <summary>
/// Default contructor
/// </summary>
public FtpClient()
/// <summary>
/// </summary>
/// <param name="server"></param>
/// <param name="username"></param>
/// <param name="password"></param>
public FtpClient(string server, string username, string password)
this.server = server;
this.username = username;
this.password = password;
/// <summary>
/// </summary>
/// <param name="timeoutSeconds"></param>
/// <param name="port"></param>
public FtpClient(string server, string username, string password, int timeoutSeconds, int port)
this.timeoutSeconds = timeoutSeconds;
this.port = port;
/// <summary>
/// Display all communications to the debug log
/// </summary>
public bool VerboseDebugging
get
return this.verboseDebugging;
set
this.verboseDebugging = value;
/// <summary>
/// Remote server port. Typically TCP 21
/// </summary>
public int Port
get
return this.port;
set
this.port = value;
/// <summary>
/// Timeout waiting for a response from server, in seconds.
/// </summary>
public int Timeout
get
return this.timeoutSeconds;
set
this.timeoutSeconds = value;
/// <summary>
/// Gets and Sets the name of the FTP server.
/// </summary>
/// <returns></returns>
public string Server
get
return this.server;
set
this.server = value;
/// <summary>
/// Gets and Sets the port number.
/// </summary>
public int RemotePort
get
return this.port;
set
this.port = value;
/// <summary>
/// GetS and Sets the remote directory.
/// </summary>
public string RemotePath
get
return this.remotePath;
set
this.remotePath = value;
/// <summary>
/// Gets and Sets the username.
/// </summary>
public string Username
get
return this.username;
set
this.username = value;
/// <summary>
/// Gets and Set the password.
/// </summary>
public string Password
get
return this.password;
set
this.password = value;
/// <summary>
/// If the value of mode is true, set binary mode for downloads, else, Ascii mode.
/// </summary>
public bool BinaryMode
get
return this.binMode;
set
if (this.binMode == value) return;
if (value)
sendCommand("TYPE I");
sendCommand("TYPE A");
if (this.resultCode != 200) throw new FtpException(result.Substring(4));
/// <summary>
/// Login to the remote server.
/// </summary>
public void Login()
if (this.loggedin) this.Close();
Debug.Print("Opening connection to " + this.server + "FtpClient");
IPEndPoint ep = null;
try
this.clientSocket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
ep = new IPEndPoint(IPAddress.Parse(this.server), this.port);
this.clientSocket.Connect(ep);
catch (Exception ex)
// doubtfull
if (this.clientSocket != null) this.clientSocket.Close();
throw new FtpException("Couldn't connect to remote server", ex);
this.readResponse();
if (this.resultCode != 220)
this.Close();
throw new FtpException(this.result.Substring(4));
this.sendCommand("USER " + username);
if (!(this.resultCode == 331 || this.resultCode == 230))
this.cleanup();
if (this.resultCode != 230)
this.sendCommand("PASS " + password);
if (!(this.resultCode == 230 || this.resultCode == 202))
this.cleanup();
this.loggedin = true;
Debug.Print("Connected to " + this.server + "FtpClient");
/// <summary>
/// Close the FTP connection.
/// </summary>
public void Close()
Debug.Print("Closing connection to " + this.server + "FtpClient");
this.sendCommand("QUIT");
this.cleanup();
/// <summary>
/// Return the size of a file.
/// </summary>
/// <param name="fileName"></param>
public long GetFileSize(string fileName)
if (!this.loggedin) this.Login();
this.sendCommand("SIZE " + fileName);
long size = 0;
if (this.resultCode == 213)
size = long.Parse(this.result.Substring(4));
return size;
/// <summary>
/// Download a file to the Assembly's local directory,
/// keeping the same file name.
/// </summary>
/// <param name="remFileName"></param>
public void Download(string remFileName)
this.Download(remFileName, "", false);
/// <summary>
/// Download a remote file to the Assembly's local directory,
/// keeping the same file name, and set the resume flag.
/// </summary>
/// <param name="resume"></param>
public void Download(string remFileName, Boolean resume)
this.Download(remFileName, "", resume);
/// <summary>
/// Download a remote file to a local file name which can include
/// a path. The local file name will be created or overwritten,
/// but the path must exist.
/// </summary>
/// <param name="locFileName"></param>
public void Download(string remFileName, string locFileName)
this.Download(remFileName, locFileName, false);
/// <summary>
/// a path, and set the resume flag. The local file name will be
/// created or overwritten, but the path must exist.
/// </summary>
public void Download(string remFileName, string locFileName, Boolean resume)
this.BinaryMode = true;
Debug.Print("Downloading file " + remFileName + " from " + server + "/" + remotePath + "FtpClient");
if (locFileName.Equals(""))
locFileName = remFileName;
FileStream output = null;
if (!File.Exists(locFileName))
output = File.Create(locFileName);
output = new FileStream(locFileName, FileMode.Open);
Socket cSocket = createDataSocket();
long offset = 0;
if (resume)
offset = output.Length;
if (offset > 0)
this.sendCommand("REST " + offset);
if (this.resultCode != 350)
//Server dosnt support resuming
offset = 0;
Debug.Print("Resuming not supported:" + result.Substring(4) + "FtpClient");
Debug.Print("Resuming at offset " + offset + "FtpClient");
output.Seek(offset, SeekOrigin.Begin);
this.sendCommand("RETR " + remFileName);
if (this.resultCode != 150 && this.resultCode != 125)
DateTime timeout = DateTime.Now.AddSeconds(this.timeoutSeconds);
while (timeout > DateTime.Now)
this.bytes = cSocket.Receive(buffer, buffer.Length, 0);
output.Write(this.buffer, 0, this.bytes);
//Thread.Sleep(1);
if (this.bytes <= 0)
break;
output.Close();
try { cSocket.Close(); }
catch (Exception) { }
if (this.resultCode != 226 && this.resultCode != 250)
/// <summary>
/// </summary>
private void readResponse()
this.message = "";
this.result = this.readLine();
if (this.result.Length > 3)
this.resultCode = int.Parse(this.result.Substring(0, 3));
this.result = null;
/// <summary>
/// </summary>
private string readLine()
this.bytes = clientSocket.Receive(this.buffer, this.buffer.Length, 0);
char[] cc = ASCII.GetChars(this.buffer);
this.message += new string(cc).Substring(0, this.bytes);
//this.message += ASCII.GetString(this.buffer, 0, this.bytes);
if (this.bytes < this.buffer.Length)
break;
string[] msg = this.message.Split('\n');
if (this.message.Length > 2)
this.message = msg[msg.Length - 2];
this.message = msg[0];
if (this.message.Length > 4 && !this.message.Substring(3, 1).Equals(" ")) return this.readLine();
if (this.verboseDebugging)
for (int i = 0; i < msg.Length - 1; i++)
Debug.Print(msg[i] + "FtpClient");
return message;
/// <summary>
/// </summary>
/// <param name="command"></param>
private void sendCommand(String command)
if (this.verboseDebugging) Debug.Print(command + "FtpClient");
//Byte[] cmdBytes = Encoding.UTF8.GetBytes(command + "\r\n");
Byte[] cmdBytes = ASCII.GetBytes(command + "\r\n");
clientSocket.Send(cmdBytes, cmdBytes.Length, 0);
/// <summary>
/// when doing data transfers, we need to open another socket for it.
/// </summary>
/// <returns>Connected socket</returns>
private Socket createDataSocket()
this.sendCommand("PASV");
if (this.resultCode != 227) throw new FtpException(this.result.Substring(4));
int index1 = this.result.IndexOf('(');
int index2 = this.result.IndexOf(')');
string ipData = this.result.Substring(index1 + 1, index2 - index1 - 1);
int[] parts = new int[6];
string[] sparts = ipData.Split(',');
for (int i = 0; i < parts.Length; i++)
parts[i] = int.Parse(sparts[i]);
int len = ipData.Length;
int partCount = 0;
string buf = "";
//for (int i = 0; i < len && partCount <= 6; i++)
// char[] charr = ipData.Substring(i, 1).ToCharArray();
// char ch = charr[0];
// if (int.Parse(ch.ToString()) >= 0)
// buf += ch;
// else if (ch != ',')
// throw new FtpException("Malformed PASV result: " + result);
// if (ch == ',' || i + 1 == len)
// try
// parts[partCount++] = int.Parse(buf);
// buf = "";
// catch (Exception ex)
// throw new FtpException("Malformed PASV result (not supported?): " + this.result, ex);
string ipAddress = parts[0] + "." + parts[1] + "." + parts[2] + "." + parts[3];
int port = (parts[4] << 8) + parts[5];
Socket socket = null;
try
socket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
ep = new IPEndPoint(IPAddress.Parse(ipAddress), port);
socket.Connect(ep);
// doubtfull....
if (socket != null) socket.Close();
throw new FtpException("Can't connect to remote server", ex);
return socket;
/// <summary>
/// Always release those sockets.
/// </summary>
private void cleanup()
this.clientSocket = null;
this.loggedin = false;
/// <summary>
/// Destuctor
/// </summary>
~FtpClient()
this.cleanup();
#region Async methods (auto generated)
WinInetApi.FtpClient ftp = new WinInetApi.FtpClient();
MethodInfo[] methods = ftp.GetType().GetMethods(BindingFlags.DeclaredOnly|BindingFlags.Instance|BindingFlags.Public);
foreach ( MethodInfo method in methods )
string param = "";
string values = "";
foreach ( ParameterInfo i in method.GetParameters() )
param += i.ParameterType.Name + " " + i.Name + ",";
values += i.Name + ",";
Debug.Print("private delegate " + method.ReturnType.Name + " " + method.Name + "Callback(" + param.TrimEnd(',') + ");");
Debug.Print("public System.IAsyncResult Begin" + method.Name + "( " + param + " System.AsyncCallback callback )");
Debug.Print("{");
Debug.Print("" + method.Name + "Callback ftpCallback = new " + method.Name + "Callback(" + values + " this." + method.Name + ");");
Debug.Print("return ftpCallback.BeginInvoke(callback, null);");
Debug.Print("}");
Debug.Print("public void End" + method.Name + "(System.IAsyncResult asyncResult)");
Debug.Print("{");
Debug.Print(method.Name + "Callback fc = (" + method.Name + "Callback) ((AsyncResult)asyncResult).AsyncDelegate;");
Debug.Print("fc.EndInvoke(asyncResult);");
Debug.Print("}");
//Debug.Print(method);
private delegate void LoginCallback();
public System.IAsyncResult BeginLogin(System.AsyncCallback callback)
LoginCallback ftpCallback = new LoginCallback(this.Login);
private delegate void CloseCallback();
public System.IAsyncResult BeginClose(System.AsyncCallback callback)
CloseCallback ftpCallback = new CloseCallback(this.Close);
private delegate Int64 GetFileSizeCallback(String fileName);
public System.IAsyncResult BeginGetFileSize(String fileName, System.AsyncCallback callback)
GetFileSizeCallback ftpCallback = new GetFileSizeCallback(this.GetFileSize);
return ftpCallback.BeginInvoke(fileName, callback, null);
private delegate void DownloadCallback(String remFileName);
public System.IAsyncResult BeginDownload(String remFileName, System.AsyncCallback callback)
DownloadCallback ftpCallback = new DownloadCallback(this.Download);
return ftpCallback.BeginInvoke(remFileName, callback, null);
private delegate void DownloadFileNameResumeCallback(String remFileName, Boolean resume);
public System.IAsyncResult BeginDownload(String remFileName, Boolean resume, System.AsyncCallback callback)
DownloadFileNameResumeCallback ftpCallback = new DownloadFileNameResumeCallback(this.Download);
return ftpCallback.BeginInvoke(remFileName, resume, callback, null);
private delegate void DownloadFileNameFileNameCallback(String remFileName, String locFileName);
public System.IAsyncResult BeginDownload(String remFileName, String locFileName, System.AsyncCallback callback)
DownloadFileNameFileNameCallback ftpCallback = new DownloadFileNameFileNameCallback(this.Download);
return ftpCallback.BeginInvoke(remFileName, locFileName, callback, null);
private delegate void DownloadFileNameFileNameResumeCallback(String remFileName, String locFileName, Boolean resume);
public System.IAsyncResult BeginDownload(String remFileName, String locFileName, Boolean resume, System.AsyncCallback callback)
DownloadFileNameFileNameResumeCallback ftpCallback = new DownloadFileNameFileNameResumeCallback(this.Download);
return ftpCallback.BeginInvoke(remFileName, locFileName, resume, callback, null);
#endregion
and here how i use it ;
ps = new PersistentStorage("SD");
ps.MountFileSystem();
byte[] ip = { 192, 168, 1, 210 };
byte[] subnet = { 255, 255, 255, 0 };
byte[] gateway = { 192, 168, 1, 1 };
byte[] mac = { 43, 185, 44, 2, 206, 120 };
WIZnet_W5100.Enable(SPI.SPI_module.SPI1, (Cpu.Pin)FEZ_Pin.Digital.Di10, (Cpu.Pin)FEZ_Pin.Digital.Di9, true); // WIZnet interface on FEZ Connect
NetworkInterface.EnableStaticIP(ip, subnet, gateway, mac);
NetworkInterface.EnableStaticDns(new byte[] { 192, 168,1, 1 });
//Dhcp.EnableDhcp(mac);
Debug.Print("Network settings:");
Debug.Print("IP Address: " + new IPAddress(NetworkInterface.IPAddress).ToString());
Debug.Print("Subnet Mask: " + new IPAddress(NetworkInterface.SubnetMask).ToString());
Debug.Print("Default Getway: " + new IPAddress(NetworkInterface.GatewayAddress).ToString());
Debug.Print("DNS Server: " + new IPAddress(NetworkInterface.DnsServer).ToString());
FtpClient ftp = new FtpClient("192.168.1.15", "test", "test");
//ftp.BinaryMode = true;
ftp.Download("test.MP3", "\\SD\\aa.mp3", true);
it works perfect… but the download speed is 8kb/s
is there any configuration option to change the speed of spi and/or ethernet shield’s speed init functions?
