Hi All,
I am using visual c++ to communicate with three ICs using I2C, from a PC via usb using a FT2232H.
The devices I am connected via I2C are 2x AD5252 and 1x AD7993. The AD7993 contains 16 bit registers which I am having trouble reading from. I have successfully written and read from the 8bit registers on all three devices, but always get incorrect results when reading the 16bit registers.
Below is a copy of the code I use for reading the 8bit registers in the AD7993 AtoD converter. The code is written in Microsoft Visual C++ 2008 Express Edition and based on code from the I2CTEST example code found at http://www.ftdichip.com/Support/SoftwareExamples/CodeExamples/VC++/I2CTEST.rar
I would appreciate it if anyone could point me to how to modify the code for reading two bytes?
///READ SECTION
//Purge USB receive buffer first before read operation
ftStatus = FT_GetQueueStatus(ftHandle, &dwNumInputBuffer); // Get the number of bytes in the device receive buffer
if ((ftStatus == FT_OK) && (dwNumInputBuffer > 0))
FT_Read(ftHandle, &InputBuffer, dwNumInputBuffer, &dwNumBytesRead); //Read out all the data from receive buffer
// Set I2C start condition
HighSpeedSetI2CStart();
bSucceed = SendByteAndCheckACK(0x58); // Address of AD5252 with LSB=0 for write command
bSucceed = SendByteAndCheckACK(0x01); // Register RDAC1 for W1
bSucceed = SendByteAndCheckACK(0x59); // Address of AD5252 with LSB=1 for read command
// Read the data from I2C device
//dwNumBytesToSend = 0; //Clear output buffer
OutputBuffer[dwNumBytesToSend++] = '\x80'; //Command to set directions of lower 8 pins and force value on bits set as output
OutputBuffer[dwNumBytesToSend++] = '\x00'; //Set SCL low, WP disabled by SK, GPIOL0 at bit ¡®0¡¯
OutputBuffer[dwNumBytesToSend++] = '\x11'; //Set SK, GPIOL0 pins as output with bit ¡¯1¡¯, DO and other pins as input with bit ¡®0¡¯
OutputBuffer[dwNumBytesToSend++] = MSB_FALLING_EDGE_CLOCK_BYTE_IN; //Command to clock data byte in on ¨Cve Clock Edge MSB first
OutputBuffer[dwNumBytesToSend++] = '\x00'; //Data length of 0x0000 means 1 byte data to clock in
//OutputBuffer[dwNumBytesToSend++] = '\x87'; //Send answer back immediate command
OutputBuffer[dwNumBytesToSend++] = MSB_RISING_EDGE_CLOCK_BIT_IN; //Command to scan in acknowledge bit , -ve clock Edge MSB first
OutputBuffer[dwNumBytesToSend++] = '\x0'; //Length of 0 means to scan in 1 bit
ftStatus = FT_Write(ftHandle, OutputBuffer, dwNumBytesToSend, &dwNumBytesSent); //Send off the commands
ftStatus = FT_Read(ftHandle, InputBuffer, 2, &dwNumBytesRead);//Read one byte from device receive buffer, may need try more times
ByteDataRead = InputBuffer[0]; //return the data read from EEPROM
OutputBuffer[dwNumBytesToSend++] = '\x02'; //Set SDA high, SCL low, WP disabled by SK at bit '0', DO, GPIOL0 at bit '1'
OutputBuffer[dwNumBytesToSend++] = '\x13'; //Set SK,DO,GPIOL0 pins as output with bit ¡¯1¡¯, other pins as input with bit ¡®0¡¯
HighSpeedSetI2CStop();
Jonathan
