Hi
ive been looking at some Arduino code, that does some stuff that i would like to do in netmf instead.
But not sure how it would translate to c#…
This is the Arduino code:
int angle = 3000//angle is int 500 to 5500
unsigned int temp;
byte pos_hi,pos_low;
temp = angle & 0x1f80; //get bits 8 thru 13 of position
pos_hi = temp >> 7; //shift bits 8 thru 13 by 7
pos_low = angle & 0x7f; //get lower 7 bits of position
Anyone who is familiar with both languages, that might be able to help me out?
int angle = 3000;//angle is int 500 to 5500
int temp;
pos_hi = (byte)(temp >> 7); //shift bits 8 thru 13 by 7
pos_low = (byte)(angle & 0x7f); //get lower 7 bits of position
yes, it should If I thought I could get away with it, I’d say that was a deliberate change put in there to see who was paying attention (Ian) but I can’t; I forgot I’d chopped unsigned off and didn’t U it.
