Judith
March 10, 2013, 4:51am
1
I’m trying to run keyboard emulator that send some key every x seconds,
I saw that it’s work only when the USBClientController state is running.
usually the USBClientController is in attached state.
Do you know how can I change the state manually?
thanks,
Judith.
Judith
March 10, 2013, 9:03am
3
Maybe I can cause state change somehow?
sometimes it’s in ‘Running’ state and I don’t know what is depends on.
Isn’t it “attached” when USB is plugged in and “running” when the drivers are loaded? (When windows calls USBSetConfig).
Judith
March 10, 2013, 9:19am
5
I thought so, but also after I ran:
kb = USBClientController.StandardDevices.StartKeyboard();
the USBClientController state is “attached”.
What do you see on device manager where you have the USB plugged in?
What happens if you unplug and replug the cable back in?
Judith
March 10, 2013, 9:27am
7
I work with rs232 for debugging and the USBClientDP connect to another PC.
Yes, I know What do you see on the “other” PC device manager.
Judith
March 10, 2013, 9:38am
9
nothing changed in the device manager when I unplug and re plug the cable back in
