I’m using a 16Mb FLASH chip instead of the standard 4Mb flash. It works fine using the standard GHI Flash driver after I downloaded the Flash_42 source code and changed MAX_ADDRESS to 0xFFFFFF and I can access the full 16Mb.
However, now I would like to use the Flash File System. By default it just use 4Mb of my flash chip, and there does not seem to be any way to change it. I could also not find the source code for the FLASH File System anywhere. It is still very useful, but if there is a way to use the full 16Mb then that would be even better.
So my questions are:
- Is there a way to force the FLASH file system to use the full 16Mb of my flash chip?
- Is the Flash File System source code available somewhere?
