I discovered this part of the world recently and am now playing with a FEZ spider.
I have managed to write some simple code for the spider in Visual c#, but it says the firmware is the wrong version.,
So I have used fez config and it says I have no firmware… When I go to update the firmware, it gives me a problem.
IT goes to check the signature of the device and it fails everytime. I cannot figure out how to update this manually as everytime i do my research, i end up on the same support page…
Some photos are attached, anyone have any ideas for what the problem could be?
And let me just add that I have never managed to update Spider firmware with anything else than Teraterm… the legacy updaters only works for some people.
hmm, cross posted. It looks like you have the right version of tinybooter, but needs the firmware. That part should be easy with FezConfig013, so I dont understand what might be the problem.
I’m not @ work right now, and I don’t have a device to connect here; so, this is from an old guys memory: if you want to avoid the usb->serial, serial->usb switching, go into FEZ Config, go to Deployment Advanced, where it says “friendly name” make sure it says “gadgeteer”; if doesn’t enter it that way. Tell Fez config to do it. – The friendly name is part of the USB name and will allow visual studio to (in most cases) recognize your device automatically.
