Hello
I so hope that I post here in the correct section for my lill issue…
Probably most of you will laugh when you see my problem >.<
I work actually on my very first GadgeteerApp. Sofar I just have good Java knowledge… i expanded it to c# with a short crashcourse.
I installed all needed Programms and connected my FEZ Hydra (but Button1.4 and a LED7R)
The setup did work quiet well… i followed the tutorial on the FEZSpider Kit Guide.
Just somehow i don’t the the Button Event handling to work.
By typing “button.” I should get the selection to get “ButtonPressed” and so on… but somehow the button. is unknown to my program. do i have to initialize it manual somewhere or so?
Thx for a small tip to a beginner.
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace GadgeteerApp1
public partial class Program
timer.Tick +=<tab><tab>
timer.Start();
button.
