Error: the reference GHIElectronics.TinyCLR.Devices.Uart cannot be used with this version of the firmware.
Firmware checksum 0x3E687729 does not match the assembly checksum 0x8A8E94F6.
The code on the dev branch has checksums that change often to reflect the state of the libraries as they change. The libraries on NuGet can only be used with the code on the master branch
no, DEV branch is where breaking changes may happen. MASTER is the point-in-time, known-good release. Given you have seen the above error, that is caused by you trying to use parts of DEV and everything else from MASTER, it makes no sense to do this, you should just use MASTER…
