I have a Cerbuino Bee to which I want to attach a Gadgeteer ENC28 module and a header module which will be configured as a software I2C port.
If I want to use the Gadgeteer assemblies I know how to do this using the diagram and that is all working.
However I am RAM constrained and with really only one Gadgeteer module I would like to skip all the overhead and use just NETMF.
I found the document which explains the networking part, along with the line of code:
and the instructions: [quote]Make sure that you update the pins in the constructor to match your hardware setup.[/quote]
This is where I run into problems.
There is a posting where Gus explains how to get the Pin values using Gadgeteer. I had actually already figured that out myself.
But I have been unable to figure it out using just NETMF. I have looked at the schematics of the module and mainboard, so I know all the pins on the sockets I want to use and what they are connected to on the processor, but I don't know how to use that to get the needed values for the Pin enumeration.
Can someone post a fragment to show how to get those Pin values or point me to where I can find it.
Thanks.
