So I traced down all the code that might modify the write time. Turns out the FAT_LogicDisk.cpp’s FAT_LogicDisk::GetFile method updates the LastWrite time.
The Write method also does, so I just commented out the “dirEntry->Set_DIR_WrtDate” lines in the GetFile method. …Maybe this isn’t the best solution, but magically it works now!!!
I think the Open method always specifies CREATE_FILE.
Another bug, NETMF’s LastAccessed only stores the date, never the time. But before I think too hard, is that for a good reason? Am I missing some obvious reason why we wouldn’t want to store the time?
Wow, and System.IO.File.Move updates Created, Written and Accessed … why? A file is MOVED not changed. This info should be preserved right? Checkout FAT_LogicDisk.cpp’s Move method…
HRESULT FAT_LogicDisk::Move( LPCWSTR oldPath, LPCWSTR newPath )
TINYCLR_HEADER();
UINT32 oldPathLen, newPathLen;
FAT_FILE srcFileInfo, destFileInfo;
FAT_Directory* dirEntry;
BYTE bytData[sizeof(FAT_Directory) - FAT_Directory::DIR_Name__size];
TINYCLR_CHECK_HRESULT(FAT_Utility::ValidatePathLength( oldPath, &oldPathLen ));
TINYCLR_CHECK_HRESULT(FAT_Utility::ValidatePathLength( newPath, &newPathLen ));
dirEntry = GetFile( oldPath, oldPathLen, &srcFileInfo );
//check src path legal
if(!dirEntry)
TINYCLR_SET_AND_LEAVE(CLR_E_FILE_NOT_FOUND);
// Store all the meta data, except the name
memcpy( bytData, &dirEntry->DIR_Attr, sizeof(FAT_Directory) - FAT_Directory::DIR_Name__size );
// Always create a file here, since we don't need it to allocate an extra cluster.
dirEntry = GetFile( newPath, newPathLen, &destFileInfo, GetFile__CREATE_FILE | GetFile__FAIL_IF_EXISTS );
if(!dirEntry)
TINYCLR_SET_AND_LEAVE(CLR_E_PATH_ALREADY_EXISTS);
// Copy the meta data from the temp storage
destFileInfo.MarkDirectoryEntryForWrite();
memcpy( (void*)(&dirEntry->DIR_Attr), bytData, sizeof(FAT_Directory) - FAT_Directory::DIR_Name__size );
UINT16 date,time;
UINT8 timeTenth;
FAT_Utility::GetCurrentFATTime( &date, &time, &timeTenth );
// dirEntry->Set_DIR_CrtDate ( date ); //BS 1/14/14: Move should not change any of these dates.
// dirEntry->Set_DIR_CrtTime ( time ); //BS 1/14/14: Move should not change any of these dates.
// dirEntry->DIR_CrtTimeTenth = timeTenth; //BS 1/14/14: Move should not change any of these dates.
//dirEntry->Set_DIR_WrtDate ( date ); //BS 1/14/14: Move should not change any of these dates.
//dirEntry->Set_DIR_WrtTime ( time ); //BS 1/14/14: Move should not change any of these dates.
// dirEntry->Set_DIR_LstAccDate(date); //BS 1/14/14: Move should not change any of these dates.
// Delete the old entry
TINYCLR_CHECK_HRESULT(srcFileInfo.DeleteDirectoryEntry());
TINYCLR_NOCLEANUP();
Obviously I commented out that code on my version, I need that info to stay constant. My user’s view lists of files in folders on the SD card. They’re sorted by LastWritten, so the newest are on top.
I do not believe this is a bug, originally FAT12 directory entries where defined as 32 bytes which persisted for FAT16 and FAT32, the compromise was made to store only the date for last access date.
