Oled Dispaly Module
4.USB client DP Module
Requirement:
Application#1: This application will be installed on the PC. This application is developed using C#. This Application should copy a file from the PC to the SD card of the FEZ Hydra Device/Gadgeteer.
what all solutions are there to this problem?
which solution is better/best?
On hydra, which doesn’t have premium features, you need to add USB to serial module and then this will give you a COM port on your PC. You can then use that COM port through your application to send and interpret data however fits your needs best.
