I noticed that when you cut and paste code from fezzer, you don’t get the CR-LF when pasting into VS. This makes it *very difficult to use the samples because of all the editing required. Probably on the list, but just raising a signal
Double-click on the code and it will un-format and select all. Copy and paste the selection into VS and you’ll have proper formatting. Does this fix your problem?
