I think I just found a small problem with the FillRectangle() method provided with FEZ_Components_FEZTouch.cs.
In the code, after you’ve looped though writing full buffers of data, the following code is present:
int pixelsLeft = pixelCount % bufferPixels;
if (pixelsLeft > 0)
// first half
pp.Write(buffer, 0, pixelsLeft);
// second half
I’ve run into a problem when pixelsLeft is odd. The ‘first half’ write works correctly, but writes an extra byte. Then the ‘second half’ write gets messed up (off by one, because of the earlier leftover byte). So, the rectangle gets a strange color for the last bytes.
Unless I’m missing something, a simple fix seems to be to replace the two writes with a single write, like this:
if (pixelsLeft > 0)
pp.Write(buffer, 0, (pixelsLeft * 2));
It seems to work like I would expect. But let me know if that doesn’t make sense.
What changes are you making on the original code?
I think pixelsLeft will always be 0 by default.
Also, why would it be odd? pixelCount is width*height so it is never odd
Where would the extra byte come from?
pixelsLeft will be whatever is left over that wasn’t sent as part of a full buffer (1024 bytes).
If pixelCount is width*height, pixelCount can be odd any time the product is odd (17x17 for example):
This code shows the problem:
// Color drawing canvas using touch events
namespace FEZ_Touch_Example
static FEZ_Components.FEZTouch lcd;
// This is for FEZ Panda II
FEZ_Components.FEZTouch.LCDConfiguration lcdConfig = new FEZ_Components.FEZTouch.LCDConfiguration(
FEZ_Pin.Digital.Di28,
FEZ_Pin.Digital.Di20,
FEZ_Pin.Digital.Di22,
FEZ_Pin.Digital.Di23,
new FEZ_Pin.Digital[8] { FEZ_Pin.Digital.Di51, FEZ_Pin.Digital.Di50, FEZ_Pin.Digital.Di49, FEZ_Pin.Digital.Di48, FEZ_Pin.Digital.Di47, FEZ_Pin.Digital.Di46, FEZ_Pin.Digital.Di45, FEZ_Pin.Digital.Di44 },
FEZ_Pin.Digital.Di24,
FEZ_Pin.Digital.Di26
FEZ_Components.FEZTouch.TouchConfiguration touchConfig = new FEZ_Components.FEZTouch.TouchConfiguration(
SPI.SPI_module.SPI2, FEZ_Pin.Digital.Di25, FEZ_Pin.Digital.Di34
lcd = new FEZ_Components.FEZTouch(lcdConfig, touchConfig);
lcd.FillRectangle(0, 0, FEZ_Components.FEZTouch.ScreenWidth, FEZ_Components.FEZTouch.ScreenHeight, FEZ_Components.FEZTouch.Color.Black);
lcd.FillRectangle(1, 2, 17, 17, FEZ_Components.FEZTouch.Color.Green);
Has anyone looked into how much faster some of the drawing methods in the FEZTouch class would run using RLP?
I have it on my list of things to look into, but would hate to start if anyone is close to posting their own solution (lots of other things on my to-do list!)
The basic drawing methods aren’t bad if you don’t do too many of them, or too often. However, if you want to create more dynamic/complex displays, improved drawing speed would be very useful. I noticed that many of the controls I created in the FEZTouch UI Controls library [url]http://code.tinyclr.com/project/328/fez-touch-ui-controls/[/url] were sluggish, or in some cases, unusable. You can see examples in the video I attached to the submission.
I don’t know how much improvement you’d see if the methods could be implemented using RLP, which is why I was curious about it.
@ Peddy none as far as I’ve seen. I originally wrote all the methods in RLP but found their Managed counterparts to be faster because of the invoke overhead. Only exception is Alpha-blended stuff.
@ Skewworks - Can you give more explanation of what you mean by the “invoke overhead”? At what level did you try to use RLP? For example, did you try writing the entire FillRectangle() functionality in RLP? Or did you use RLP for the “lower level” methods (WriteRegister(), for example)?
It seems like there would only be a single invoke if the entire FillRectangle() was implemented in RLP. Or maybe I’m not understanding how it all works. ???
Yes I was thinking about using FillRectangles. So I am not sure how soon this can be added it to the official driver because we have to try several things.
The driver is well optimized. The bulk part is in ParallelPort which is done natively. It writes many pixels at once (with one invoke).
It should be faster in RLP but I think it would be just small improvements…
On the other hand, FillCircle with writing each pixel separately, means hundreds of invokes from C#. Almost all the time is spent in C# so it will be very slow.
