Addressable RGB LED to go across your room or even your house!!
Addressable RGB LED means you can control any LED individually to any color you like, hundreds of colors!
Did you ask if these can be chained to fill a whole wall with LED? Oh yes you can! Keep in mind that you can cut the LED strips in any length you want, make it small, make it large, make it colorful. This is why it is called festive, it is FEZtive
Forgot to mention that there is circuitry on the module to make use of SPI chip select pin. This way you can connect these and still use SPI for other things.
SPI is very fast. You can almost build a whole wall and play video on it! We love LEDs as much as you do!
Here’s a 24x8 grid i did awhile ago with these strips and some other micro. I have since ported the library to NETMF - it does the alphabet in 8x8. I’ve still got to add numbers and special characters. Once this module gets released, I’ll put it up on codeshare. Makes for a great marquee style scrolling sign. Gus is right - pictures don’t do these strips justice. They are really bright, and loads of fun.
I was going to buy some strips from Alibaba and do some blinkies. I even wrote an “emulator” to run on my T35 so I could work out my logic a bit ahead of time.
The timing couldn’t be better. I’ve been shopping around for these for the past few days. Had limited success with other light strips , any speculation as to the chip type or release date ?
Yes we will offer this with everything you need. We are really trying to get you this before the holidays. We can’t provide more info as things can change till then.
What chipset is used is not an important oint as we will give you the drivers needed. All you have to do is something like FEZtive.SetLED(ledNumber, red, green, blue);
@ Justin that would be another module I’m waiting for.
Question about the FEZtive module, how long a string can I drive with this? Could I drive a 15 meter string with it? Is there a max length (gotta put in landing lights for Santa Claus as I know he’ll be heavily ladened this year with GHI goodies)
So does it have to be 5 strings (I’m not sure I have enough space for 5 on the Eavestrough/Fascia, I guess I could run different strings in different places but then I’d be worried about different lengths ie around the windows etc). I’ve also seen a rumor that some folks recommend power connections every 5 meters or so (want that big LED density). Chance that the FEZtive module will be daisy chainable?
