I am trying to track down a problem I have with one of my applications
***** ASSERT ***** received as soon as the program begins.
I receive the assert as soon as I step (F11) past
It must be related to something in my code because I do not receive the assert using other applications. If it matters, the application with the error, is using Touch.
The assert does not seem to harm anything. The code runs as I would expect.
Is ASSERT related only to the LCD (Using a T35) or are there other things that cause it?
(Sorry, but I have no idea what assert is telling me)
Not really an issue to me (for the moment) but I would sure like to know what is causing it. The code is rather large so sort of hard to track down.
Using a USB Hub 2.5Amp power supply.
Using WINusb
Using VS2010 and 2012 same problem.
I will try adding my Power output for the LCD (Just thought of it while typing this)
Have a GREAT day!
UPDATE: Power output module did not help.
