jos
August 29, 2011, 9:33am
1
Hello out there,
Today my FEZ Ultimate kit arrived. And I started with the Fez touch.
The example comes with this error:
Error 3 The name ‘FEZ_Pin’ does not exist in the current context E:\FEZ Touch\FEZ Touch Example\FEZ Touch Example\Program.cs 21 17 FEZ Touch Example
Who can help me?
Thanks in advance,
Jos
Jos, Make sure that you have the latest firmware on your FEZ Panda II.
Mike
August 29, 2011, 9:44am
3
sounds like you are missing a using statement and/or a reference.
Did you create your project with one of the GHI project templates?
Show us you code…
jos
August 29, 2011, 12:24pm
4
Hi Joe,
This is what is currently in there
ClrInfo.clrVersion: 4.1.2821.0
ClrInfo.clrVendorInfo: Microsoft Copyright © Microsoft Corporation. All rig
ClrInfo.targetFrameworkVersion: 4.1.2821.0
SolutionReleaseInfo.solutionVersion: 4.1.5.1
SolutionReleaseInfo.solutionVendorInfo: GHI Electronics, LLC
SoftwareVersion.BuildDate: Apr 11 2011
SoftwareVersion.CompilerVersion: 410561
jos
August 29, 2011, 12:27pm
5
Hai Mike,
The code is the solution and all other code from the FEZ Touch example.
I made no alterations.
Regards,
Jos
Latest firmware is 4.1.6.0. Looks like you’re using 4.1.5.1. Upgrading will probably fix your problem. Hit “reply” and see #1 .
jos
August 29, 2011, 1:00pm
7
Hi Guys,
I updated my firmware to 4.1.6.0. still have the same problem however.
And my problem occurs already in the editor before I come to the hardware.
so even building is impossible
Thanks for your responses so far,
Regards,
Jos
You must also update the references in your projects to match the new firmware. The most straightforward way to do initial testing is to use on of the built in product templates.
jos
August 29, 2011, 1:50pm
9
Hi Guys,
I re installed the SDK now it works.
Thank you for your contributions.
Regards,
Jos
