OK. More information on SBASIC syntax.
The following syntax for an IF statement is NOT supported:
if x <= 10 then goto 20
The only supported IF statement format is:
[quote]if x <= 10 then
goto 20
end if[/quote]
Also, the comparison operator <= is not working correctly. The expression x <= 10 parses into pieces “x” “<” “=10”. Instead of “x” “<=” “10”.
Should be an easy fix. I will get to it later today, and post the correction.
