Hello , what is the preferred way to connect FEZ.Stick to an Ethernet LAN? Is it possible to connect a J0011D01BNL RJ45 directly (like on Devboard 20260D) and if yes, which Pins have to be connected?
Thanks in advance!
you can use ENC28J60.
Like dat pointed out. They are available from cina dirt cheap or you can use nicer ones from mikroe
Thanks, I‘ll take the nicer ones…
