Hello everyone
This is my first thread here, please move it if i’ve placed it wrong. I habe a Problem which is maybe very Simple for you, but i don’t get it.
I have a Sparkfun SI4703 Evaluation Board (https://www.sparkfun.com/products/10663) which is connected over I2C with the FEZ Spider Board on Port 4 and a Breakout Board. The I2C Connection is “established” and Working. The Module is also initialized with the following Code to 2 Wire I2C Mode:
OutputPort RST = new OutputPort((Cpu.Pin)Pin.IO1, false);
OutputPort SDA = new OutputPort((Cpu.Pin)Pin.IO0, false);
RST.Write(false);
SDA.Write(false);
Thread.Sleep(10);
RST.Write(true);
SDA.Write(true);
Thread.Sleep(200);
I2CDevice.Configuration con = new I2CDevice.Configuration(0x10, 400);
I2CDevice MyI2C = new I2CDevice(con);
But my Problem now is, that i don’t know how i have to write and Read to and from the Register. A Screenshot of the register is attached. Probably the 2 Bytes length is confusing me…
What command do i need, as example, to write the ENABLE Bit in Register 02h to 1 ?
This is not working:
{ 2,1 };
xActions[0] = I2CDevice.CreateWriteTransaction(RegisterNum);
Has anyone a hint for me ?
Best Regards from Switzerland (:
