My FEZ board I’ve been successfully using for a while has suddenly stopped. After reading the details below, can anyone help confirm my suspicion that its dead? Or suggest any CPR maneuvers to resurrect it? Also, is there a warranty on these?
Device: FEZ Spider
OS: Win 8 (also tried Win 7 on another PC)
What I tried:
[ol]Plug into PC, no response from PC. No driver loaded. Power light on Spider is on.
Plug Cerberus into same PC (same cable, same USB Client DP Module) - works fine. Driver loads, device is seen.
Plug Spider into another PC (Win 7). Same issue, no driver load.
While device is plugged into PC, press reset button on Spider. Still nothing.[/ol]
Also note: I can get the device to be recognized by the PC in Loader and TinyLoader mode, but not Default mode (switch 1,2 & 3 off, switch 4 on, right?).
I can’t really do much if the device cannot even be seen on the PC. Am I screwed?
