Hello,
I am getting an error message using the Fez Spider and Music Module. Using VS 2010 and the latest SDKs.
[quote]An unhandled exception of type ‘System.Exception’ occurred in GTM.GHIElectronics.Music.dll
Additional information: Failed to initialize MP3 Decoder.
[/quote]
[quote]Using mainboard GHI Electronics FEZSpider version 1.0
#### Exception System.Exception - 0x00000000 (1) ####
#### Message: Failed to initialize MP3 Decoder.
#### Gadgeteer.Modules.GHIElectronics.Music::.ctor [IP: 00bd] ####
#### IntelliSight.Program::InitializeModules [IP: 001f] ####
A first chance exception of type ‘System.Exception’ occurred in GTM.GHIElectronics.Music.dll
WARN: Total initialization time exceeds 10 seconds.
: ProgramStarted is blocking execution, which means events and timers will not run properly.
: Make sure not to use blocking code such as while(true) - use a GT.Timer instead.
Uncaught exception
[/quote]
There is no code that explicitly refers to music module (besides the initialization code the designer generates).
